3.7 and plex integration (opacity)
whinette
Post by whinette » 19 Sep 2018, 17:44
Hello,
3.7 is a nice improvement with plex integration displaying node on the vertical home bar, but the content displayed isn't adequate.
I.e.: I have 4 libraries in plex, 2 by type (film / tv).
Each node appear correctly, but the 'recently added' and 'in progress' are common for each library type.
While using spmc with 'kodi plexconnect', i was able to get correct 'on deck' information for each node, it should be doable into spmc.
As it is, I find it less ergonomic than the 3.6 (and older) presentation.
Bonus featurette: being able to set custom refreshing background from fanart in current library would be a huge plus.
Cheers,
whinette
