Select transconding quality per movie
fbrassin
Post by fbrassin » 19 Sep 2018, 12:31
Hello,
i've used mrmc till know with plex addon.
Now in 3.7 version i'd like to use the new ariana skin that i find very nice.
But i cannot find the option to play a movie with a particular quality of transcoding.
I just found transcoding option that i think will be used for every movie.
Can i choose quality while a plplay the movie some how?
Tnx
Re: Select transconding quality per movie
Post by davilla » 19 Sep 2018, 12:50
transcode quality is a global setting as it relates to the bit rate of your network connection.
Here, size does not matter :) It's bit-rate that matters.
fbrassin
Post by fbrassin » 19 Sep 2018, 13:12
As i stream my movies from a vpn, sometimes i can afford to stream at high bitrate during day, but at night when my two sons are using bandwidth i must reduce bitrate to stream without problems. This is the reason why i need to control it per movie as i do with plex addon.
Can something be done?
