Adjustable playback speed?
stkelly52
Post by stkelly52 » 19 Sep 2018, 07:32
I am just discovering MRMC and I would like to try it, but for my uses, I need a player that allows for adjustable playback speeds on my Nvidia Shield. I currently use VLC, which works OK, but I'm not fond of the interface. I used to like XBMC years ago, and I loved the interface, but they didn't support adjustable speeds at the time. If MrMC does this then I will purchase it.
Re: Adjustable playback speed?
Post by davilla » 19 Sep 2018, 12:44
stkelly52 wrote:
19 Sep 2018, 07:32
Sorry, adjustable speeds is very low on our priority list. If you need this then VLC is a better choice.
