SHIELD controller not working on LITE version.
Skyrider
Post by Skyrider » 02 Aug 2018, 12:36
I just installed the lite version of MrMC and noticed that the SHIELD controller isn't working with the app. Is there any specific reason for this?
You guys also might want to look at the reviews at: https://play.google.com/store/apps/deta ... .mrmc.lite
It seems all reviews are being ignored, and it has tons of negative ones as well. Doesn't really look to good in my opinion.
Re: SHIELD controller not working on LITE version.
Post by cosmoxl » 02 Aug 2018, 13:31
If the reviews are that they don't like it because they can't install add-ons that give them illegal content there's not much to respond to. They have a religious fervor for Kodi. It would be a waste of time to try to argue.
I just tested the controller on the full version. Works fine. Devs will have to respond re lite version.
Post by koying » 02 Aug 2018, 15:06
What exactly is not working with the controller?
Nothing at all?
Users browsing this forum: No registered users and 12 guests
