mySQL error 1045
jabohn
mySQL error 1045
Post by jabohn » 20 Jul 2018, 01:25
I've installed mySQL on my iMac and I'm using the instructions to set it up for MrMC. I'm in the terminal and I can't even get past the first command:
sudo /usr/local/mysql/bin/mysql
I enter my password and I get this:
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
Any ideas?
I assume the requested password is my computer account's password.
Re: mySQL error 1045
Post by timstephens24 » 20 Jul 2018, 01:44
Try just doing:
mysql -u root -p
jabohn
Post by jabohn » 20 Jul 2018, 01:49
Thanks. I got further but now there's another error:
sudo cp my-huge.cnf /etc/my.cnf
cp: my-huge.cnf: No such file or directory
Post by amet » 20 Jul 2018, 07:59
ls /usr/local/mysql/support-files/
What does ^^^ give you?
Also, pastebin the entire terminal output when you get an error to give us a chance to try to help you... one liners don’t have enough info
jabohn
Post by jabohn » 20 Jul 2018, 15:56
This is what I get Amet:
Last login: Thu Jul 19 20:59:06 on ttys000
jMac:~ jabohn$ ls /usr/local/mysql/support-files/
magic mysql.server
mysql-log-rotate mysqld_multi.server
jMac:~ jabohn$
jMac:~ jabohn$
Post by timstephens24 » 20 Jul 2018, 21:12
MySQL on the Mac doesn't use a my.cnf file by default, so it's not downloaded in the support-files folder. You can't copy a file that doesn't exist is basically what the error is telling you :p
It should be listening on 3306 and 33060 on all interfaces I believe. What's the output of this command:
sudo lsof -n -P -i4TCP | egrep "3306"
jabohn
Post by jabohn » 20 Jul 2018, 21:47
Here you go... (side note: I guess the Mac instructions on the wiki aren't exactly correct)
Last login: Fri Jul 20 08:54:53 on ttys000
jMac:~ jabohn$ sudo lsof -n -P -i4TCP | egrep "3306"
Password:
mysqld    82959 _mysql   19u  IPv6 0x13e9f6212ff1a6b3      0t0  TCP *:3306 (LISTEN)
mysqld    82959 _mysql   22u  IPv6 0x13e9f6212ff1a0f3      0t0  TCP *:33060 (LISTEN)
jMac:~ jabohn$
Post by timstephens24 » 20 Jul 2018, 22:09
Try connecting from inside MrMC Settings -> Services -> MySQL and see what happens. If that doesn't work I'll load up mysql on my Mac and take a look.
jabohn
Post by jabohn » 21 Jul 2018, 00:44
Okay, well I gave it a shot but the guide doesn't even say what to do on MrMC. I put in my computer's IP for the address and put in the password I created when installing mySQL but at no point did mySQL prompt me to create a username so I just put root. Anyway, it didn't work and MrMC said to check my settings.
Post by timstephens24 » 21 Jul 2018, 00:52
You need to run these commands:
/usr/local/mysql/bin/mysql -u root -p
<Insert MySQL root password>
CREATE USER 'mrmc' IDENTIFIED BY 'mrmc';
GRANT ALL ON *.* TO 'mrmc';
exit
What that will do is log in to your MySQL database as root, create a user named mrmc with a password of mrmc and then exit.
In MrMC set the user name to mrmc and the password to mrmc and put in the IP of your Mac. Leave the port and the names of the databases at the default value and then try to enable it.
