Can MrMC "see" DTS-HD-MA audio tracks from Plex?
pdxdude
Post by pdxdude » 05 Jun 2018, 21:16
I recently noticed that when I use the Plex plugin, my movies with DTS-HD-MA audio only show up as having regular DTS audio. My confusion is mostly because when I use a different app like Infuse, Plex will send over the full DTS-HD-MA audio.
Is this a configuration issue, or an upcoming feature perhaps?
Thanks in advance for any advice!
Re: Can MrMC "see" DTS-HD-MA audio tracks from Plex?
Post by cosmoxl » 05 Jun 2018, 21:20
Yes, MrMC can play DTS-HD MA.
MrMC is setup so that Plex doesn't hold anything back or transcode, unless you specifically tell it to do so.
pdxdude
Post by pdxdude » 05 Jun 2018, 21:36
Got it, thank you -- any reason why it would reflect the inferior codec instead of DTS-HD-MA?
