Android RAW Passthrough and VC-1 support
lukePL
Post by lukePL » 28 May 2018, 08:52
Hello!
Yesterday I've tested MrMC and it's pretty good. However it lacks one of features which is available in SPMC. I can't select RAW Passthrough which is necessary for DD output on my Philips Android TV (POS9002).
Also I have a question about VC-1 which is hardware accelerated by SoC and MX Player handles it properly however every Kodi branch treats it with software decoding. Is there anything about to do with this?
Re: Android RAW Passthrough and VC-1 support
Post by koying » 28 May 2018, 09:34
lukePL wrote:
28 May 2018, 08:52
in MrMC, RAW passthrough is enabled by disabling "Passthrough is IEC packed" option
lukePL wrote:
28 May 2018, 08:52
If you can provide a VC1 sample working in MX Player in HW+ (ie the mediacodec api) mode, there is surely something we can do about it.
Post by cosmoxl » 28 May 2018, 13:33
There's no problem with VC1 in MrMC.
I play VC1 files with the decoder AMC-VC1(s). Just did it to make sure I wasn't going crazy. :)
lukePL
Post by lukePL » 31 May 2018, 14:35
Thanks for reply guys!
Passthrough isn't working even after unchecking IEC, so I can't tell what's the diffrence between SPMC and MrMC.
VC-1 in MX Player is decoded via HW not HW+. It does some decent job while decoding with HW acceleration - everything is smooth and fluid. However I can't switch to HW+ decoding even after manual setup.
lukePL
Post by lukePL » 22 Jun 2018, 08:25
Sorry for bumping the thread but is there a possibility to address issue with passthrough?
IEC is disabled but still my AVR is dead silent. KODI does it automatically, on SPMC I'm taking RAW Passthrough. With MrMC nothing works :(
My TV is Philips 55POS9002 on Android 7. Thanks in advance.
Post by amet » 22 Jun 2018, 11:39
Debuglog will be needed
Users browsing this forum: Google [Bot] and 5 guests
