SIMPLE IPTV Client
spotless7325
SIMPLE IPTV Client
Post by spotless7325 » 08 Apr 2018, 19:11
Hi all. I´m pretty new to MrMC. I´m using MrMC on my Apple tv4
I got a few questions.
First of all, when MrMC loads the channels, it takes quite a long time to do it.
Second, If I sort, remove and make custom channelgruops, they go back to standrad when I start the app again.
And third, Is there a way to sort my channelgroups? Under groupmanagment I can only see Add group, Change name on groups, Hide group and Remove group. I would like to change the order of my channelgroups.
Is there anyone that can answer my questions?
Kind regards.
Ted377
Re: SIMPLE IPTV Client
Post by Ted377 » 09 Apr 2018, 02:24
You have to arrange the channels in the .m3u file as you want them.
An example:
# EXTM3U
#EXTINF: 0, Das Erste HD
rtsp: //192.168.10.44: 554 / freq = 330 & bw = 8 & msys = DVBC & mtype = 256 QAM & sr = 6900 & specinv = 0 & pids = 0,16,17,18,20,5100,5101,1170,2171,2172,5102,5103,5104 , 5105
#EXTINF: 0, ZDF HD
rtsp: //192.168.10.44: 554 / freq = 450 bw = 8 & msys = DVBC & mtype = 256 QAM & sr = 6900 & specinv = 0 & pids = 0,16,17,18,20,6100,6110,6120,6121,6123,6130,6131,6170
#EXTINF: 0, NDR FS NDS HD
rtsp: //192.168.10.44: 554 / freq = 458 & bw = 8 & msys = DVBC & mtype = 256 QAM & sr = 6900 & specinv = 0 & pids = 0,16,17,18,20,5220,5221,5222,5223,5224,5225
So you can create groups:
#EXTM3U
#EXTINF:-1 tvh-chnum="1" group-title="Free TV",Das Erste HD
#EXTINF:-1 tvh-chnum="2" group-title="Free TV",ZDF HD
Unfortunately, the sorted channels can not be saved via MrMC or Kodi. The stations are always queried in the order of the .m3u file.
I hope I could help you.
Users browsing this forum: porter44 and 5 guests
