Won't scan TV Shows with themoviedb  [SOLVED]
_roidy
Post by _roidy » 26 Dec 2017, 14:35
AppleTV 4k, MrMC 3.4.0
Just install and I'm setting up my libraries, my movies all scan in fine using The Movie Database scraper, however when trying to scan in my TV Shows using The Movie Database scraper every item gives the following message and nothing scans:-
Couldn't download information
Unable to connect to remote server. Would you like to continue scanning?
It's not a problem with tmdb because I have Kodi 17.6 installed on two other devices, a S905X box and a Windows PC and they both connect to tmdb and scan fine.
Any help please.
Re: Won't scan TV Shows with themoviedb
Post by amet » 26 Dec 2017, 15:18
the moviedb works fine here, I just tested by creating new library on my end.
anything useful in debuglog?
_roidy
Post by _roidy » 26 Dec 2017, 16:54
Thanks for the quick reply, here the log:-
Looking at it, everytime MrMC trys to access themoviedb's api it return a 401 error as I said Movies scan in fine from themoviedb it's only TV Shows that error.
Seems the api key is invalid, following the url in the log returns:-
"status_code": 7,
"status_message": "Invalid API key: You must be granted a valid key.",
"success": false
Post by amet » 27 Dec 2017, 05:31
That is odd, it’s not our api key... let me check this properly and I’ll let you know.
Post by amet » 27 Dec 2017, 19:08
ok, seems we have messed up on a version bump and API key got screwed up, fixed now... sorry about that, once we get new testflight goin you can check this thread for how-to participate
_roidy
Post by _roidy » 29 Dec 2017, 11:40
Sorry for the late reply, been away from home.
Any idea when I can get hold of a version that works, I've sent an email requesting testflight access.
Post by davilla » 29 Dec 2017, 15:03
We are churning one now, once built and uploaded, should take an hour or so to get past apple's auto processing step.
_roidy
Re: Won't scan TV Shows with themoviedb  [SOLVED]
Post by _roidy » 29 Dec 2017, 17:55
Wow that was fast, working perfectly now :)
Excellent support, big thanks guys.
Post by amet » 29 Dec 2017, 20:16
thanks for the confirmation, sorry for the screwup :(
Users browsing this forum: Google [Bot] and 2 guests
