SMB Username/Password Loop still happening
Re: SMB Username/Password Loop still happening
Post by amet » 13 Dec 2017, 11:17
ganachain wrote:
12 Dec 2017, 23:00
If I turn on debug logging, how do I export the log to attach for you?
debuglog <- has all the info
ganachain
Post by ganachain » 13 Dec 2017, 11:18
Tried the default libsmbclient and libdsm and both had the same password loop. I even made sure to kill the app after selecting.
The platform that isn’t working is MrMC on iOS/tvOS.
I have SPMC on Shield that works fine.
Thanks for the debut log link. I will attach tonight when I get home from work.
ganachain
Post by ganachain » 13 Dec 2017, 21:02
Got the logs....
I used this username/password to connect on a mac via smb://192.168.0.18/movies. Same link worked on android/SPMC and Windows/Kodi
Tried entering it twice - password loop.
relevant section...
15:56:04 T:6160773120 DEBUG: ------ Window Init (DialogNetworkSetup.xml) ------
15:57:19 T:6160773120 DEBUG: ------ Window Deinit (DialogNetworkSetup.xml) ------
15:57:19 T:6160773120 DEBUG: found key /userdata/passwords.xml
15:57:19 T:6160773120 DEBUG: Previous line repeats 2 times.
15:57:19 T:6160773120 DEBUG: CPasswordManager:AuthenticateURL hasUserPass(1), path(smb://USERNAME:PASSWORD@192.168.0.18/movies)
15:57:19 T:6160773120 ERROR: CDSMSession: Auth failed, reason(-1073741715)
15:57:19 T:6160773120 DEBUG: ------ Window Init (LockSettings.xml) ------
15:57:19 T:6160773120 INFO: Loading skin file: LockSettings.xml, load type: KEEP_IN_MEMORY
15:57:19 T:6160773120 DEBUG: CSettingsManager: requested setting (user.name) was not found.
15:57:19 T:6160773120 DEBUG: CSettingsManager: requested setting (user.password) was not found.
15:57:19 T:6160773120 DEBUG: CSettingsManager: requested setting (user.rememberpassword) was not found.
15:57:37 T:6160773120 DEBUG: ------ Window Deinit (LockSettings.xml) ------
15:57:37 T:6160773120 DEBUG: found key /userdata/passwords.xml
15:57:37 T:6160773120 DEBUG: Previous line repeats 2 times.
15:57:37 T:6160773120 DEBUG: NSUSerDefaults: compressed /userdata/passwords.xml from 334 to 167
15:57:37 T:6160773120 ERROR: CDSMSession: Auth failed, reason(-1073741715)
FULL LOG...
15:55:32 T:6160773120 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:55:32 T:6160773120 NOTICE: -----------------------------------------------------------------------
15:55:32 T:6160773120 NOTICE: Starting MrMC (3.3-0 Git:2017-11-26-9b5c348). Platform: TVOS ARM64 64-bit
15:55:32 T:6160773120 NOTICE: Using Release MrMC x64 build
15:55:32 T:6160773120 NOTICE: MrMC compiled Nov 26 2017 by Clang 9.0.0 (clang-900.0.38) for TVOS ARM64 64-bit version 10.2.0 (100200)
15:55:32 T:6160773120 NOTICE: Running on Apple Inc. AppleTV6,2 with TVOS 11.2.1, kernel: Darwin ARM 64-bit version 17.3.0
15:55:32 T:6160773120 NOTICE: Host CPU: arm64 v8, 3 cores available
15:55:32 T:6160773120 NOTICE: ARM Features: Neon enabled
15:55:32 T:6160773120 NOTICE: special://xbmc/ is mapped to: /private/var/containers/Bundle/Application/FAA01914-30F8-49E9-A41F-FFE199E65F28/MrMC.app/AppData/AppHome
15:55:32 T:6160773120 NOTICE: special://xbmcbin/ is mapped to: /private/var/containers/Bundle/Application/FAA01914-30F8-49E9-A41F-FFE199E65F28/MrMC.app/AppData/AppHome
15:55:32 T:6160773120 NOTICE: special://masterprofile/ is mapped to: /var/mobile/Containers/Data/Application/144B1298-E410-4D81-A5E6-2F9B945183B8/Library/Caches/home/userdata
15:55:32 T:6160773120 NOTICE: special://home/ is mapped to: /var/mobile/Containers/Data/Application/144B1298-E410-4D81-A5E6-2F9B945183B8/Library/Caches/home
15:55:32 T:6160773120 NOTICE: special://temp/ is mapped to: /private/var/mobile/Containers/Data/Application/144B1298-E410-4D81-A5E6-2F9B945183B8/tmp/temp
15:55:32 T:6160773120 NOTICE: special://logs/ is mapped to: /var/mobile/Containers/Data/Application/144B1298-E410-4D81-A5E6-2F9B945183B8/Library/Caches/logs/
15:55:32 T:6160773120 NOTICE: special://frameworks/ is mapped to: /var/containers/Bundle/Application/FAA01914-30F8-49E9-A41F-FFE199E65F28/MrMC.app/Frameworks
15:55:32 T:6160773120 NOTICE: The executable running is: /var/containers/Bundle/Application/FAA01914-30F8-49E9-A41F-FFE199E65F28/MrMC.app/MrMC
15:55:32 T:6160773120 NOTICE: Local hostname: Apple-TV
15:55:32 T:6160773120 NOTICE: Log File is located: special://logs/mrmc.log
15:55:32 T:6160773120 NOTICE: load settings...
15:55:32 T:6160773120 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
15:55:32 T:6160773120 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
15:55:32 T:6160773120 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
15:55:32 T:6160773120 ERROR: CSetting: missing <control> tag of "videoscreen.vsync"
15:55:32 T:6160773120 WARNING: CSettingGroup: unable to read setting "videoscreen.vsync"
15:55:32 T:6160773120 NOTICE: Found 1 Lists of Devices
15:55:32 T:6160773120 NOTICE: Enumerated DARWINIOS devices:
15:55:32 T:6160773120 NOTICE: Device 1
15:55:32 T:6160773120 NOTICE: m_deviceName : default
15:55:32 T:6160773120 NOTICE: m_displayName : Default
15:55:32 T:6160773120 NOTICE: m_displayNameExtra:
15:55:32 T:6160773120 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:55:32 T:6160773120 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR
15:55:32 T:6160773120 NOTICE: m_sampleRates : 44100,48000
15:55:32 T:6160773120 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S16LE,AE_FMT_FLOAT
15:55:32 T:6160773120 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTSHD_CORE
15:55:32 T:6160773120 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:55:32 T:6160773120 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:55:32 T:6160773120 NOTICE: Default DVD Player: dvdplayer
15:55:32 T:6160773120 NOTICE: Default Video Player: dvdplayer
15:55:32 T:6160773120 NOTICE: Default Audio Player: paplayer
15:55:32 T:6160773120 NOTICE: Enabled debug logging due to GUI setting (2)
15:55:32 T:6160773120 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
15:55:32 T:6160773120 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
15:55:32 T:6160773120 DEBUG: found key /userdata/sources.xml
15:55:32 T:6160773120 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:55:32 T:6160773120 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
15:55:32 T:6160773120 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
15:55:32 T:6160773120 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/mms/udp
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: M4V
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
15:55:32 T:6160773120 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
15:55:32 T:6160773120 NOTICE: Loaded playercorefactory configuration
15:55:32 T:6160773120 DEBUG: found key /userdata/playercorefactory.xml
15:55:32 T:6160773120 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:55:32 T:6160773120 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:55:32 T:6160773120 DEBUG: found key /userdata/wakeonlan.xml
15:55:32 T:6160773120 DEBUG: found key /userdata/profiles.xml
15:55:32 T:6160773120 DEBUG: Previous line repeats 1 times.
15:55:32 T:6160773120 DEBUG: NSUSerDefaults: compressed /userdata/profiles.xml from 923 to 324
15:55:32 T:6160773120 DEBUG: found key /userdata/guisettings.xml
15:55:32 T:6160773120 DEBUG: NSUSerDefaults: compressed /userdata/guisettings.xml from 33196 to 6340
15:55:32 T:6160773120 INFO: creating subdirectories
15:55:32 T:6160773120 INFO: userdata folder: special://masterprofile/
15:55:32 T:6160773120 INFO: recording folder:
15:55:32 T:6160773120 INFO: screenshots folder:
15:55:32 T:6162493440 INFO: CActiveAESink::OpenSink - initialize sink
15:55:32 T:6162493440 DEBUG: CActiveAESink::OpenSink - trying to open device DARWINIOS:default
15:55:32 T:6162493440 DEBUG: virtual bool CAESinkDARWINIOS::Initialize(AEAudioFormat &, std::string &): AudioStreamBasicDescription: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz) pcm
15:55:32 T:6162493440 NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
15:55:32 T:6162493440 NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
15:55:32 T:6162493440 NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.021333
15:55:32 T:6162493440 NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.044500
15:55:32 T:6162493440 NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
15:55:32 T:6162493440 NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
15:55:32 T:6162493440 NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
15:55:32 T:6162493440 NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.001833
15:55:32 T:6162493440 NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.021333
15:55:32 T:6162493440 NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
15:55:32 T:6162493440 NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 8
15:55:32 T:6162493440 DEBUG: DumpAudioDescriptions: void dumpAVAudioSessionProperties()
15:55:32 T:6162493440 DEBUG: DumpAudioDescriptions: input count = 0
15:55:32 T:6162493440 DEBUG: DumpAudioDescriptions: output count = 1
15:55:32 T:6162493440 DEBUG: DumpAudioDescriptions : portName, Apple TV
15:55:32 T:6162493440 DEBUG: DumpAudioDescriptions: channelLabel, 1
15:55:32 T:6162493440 DEBUG: DumpAudioDescriptions: channelName , Apple TV 1
15:55:32 T:6162493440 DEBUG: DumpAudioDescriptions: channelLabel, 2
15:55:32 T:6162493440 DEBUG: DumpAudioDescriptions: channelName , Apple TV 2
15:55:32 T:6162493440 DEBUG: CActiveAESink::OpenSink - DARWINIOS Initialized:
15:55:32 T:6162493440 DEBUG: Output Device : Default
15:55:32 T:6162493440 DEBUG: Sample Rate : 48000
15:55:32 T:6162493440 DEBUG: Sample Format : AE_FMT_FLOAT
15:55:32 T:6162493440 DEBUG: Channel Count : 2
15:55:32 T:6162493440 DEBUG: Channel Layout: FL,FR
15:55:32 T:6162493440 DEBUG: Frames : 1024
15:55:32 T:6162493440 DEBUG: Frame Size : 8
15:55:32 T:6162493440 DEBUG: CActiveAESink::GenerateNoise - noiseFactor = 0.000010
15:55:32 T:6160773120 NOTICE: Running database version Addons20
15:55:32 T:6160773120 DEBUG: SECTION:LoadDLL(libcpluff.framework/libcpluff)
15:55:32 T:6160773120 DEBUG: Loading: /var/containers/Bundle/Application/FAA01914-30F8-49E9-A41F-FFE199E65F28/MrMC.app/Frameworks/libcpluff.framework/libcpluff
15:55:32 T:6160773120 INFO: ADDON: cpluff: 'Could not read plug-in directory /var/mobile/Containers/Data/Application/144B1298-E410-4D81-A5E6-2F9B945183B8/Library/Caches/home/addons: No such file or directory'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ca_es has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.mt_mt has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.az_az has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.vi_vn has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ja_jp has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.eo has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.images.weathericons.default has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.pl_pl has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_au has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in kodi.audiodecoder has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.fr_ca has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.argustv has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.sr_rs has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.ofdb.de has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.fa_af has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in skin.sio2 has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.bg_bg has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.hu_hu has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvblink has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.da_dk has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.mk_mk has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.pt_pt has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.nb_no has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.is_is has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ms_my has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.sv_se has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ru_ru has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.os_os has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_mx has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.nl_nl has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.musicvideos.theaudiodb.com has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ta_in has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.gl_es has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.pctv has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.slideshow has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.iptvsimple has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in skin.opacity has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ko_kr has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.fa_ir has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.njoy has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.uz_uz has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.movieposterdb.com has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.tg_tj has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.my_mm has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvbviewer has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_gb has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in skin.amber has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.port.hu has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in visualization.spectrum has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.stalker has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.hr_hr has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.zh_tw has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.fo_fo has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.zh_cn has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.local has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in xbmc.webinterface has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ro_ro has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.fi_fi has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.de_de has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.filmon has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_nz has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.szl has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_us has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.tr_tr has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in xbmc.audioencoder has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.vbox has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.mrmc has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.mymovies.dk has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.pt_br has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.id_id has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.th_th has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.sk_sk has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.vdr.vnsi has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in kodi.guilib has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.sl_si has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.system has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.am_et has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.fr_fr has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_ar has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.mediaportal.tvserver has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.eu_es has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.bs_ba has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.sr_rs@latin has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.universal has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.cs_cz has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in skin.mrmc has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.mi has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.sq_al has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.el_gr has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.hi_in has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.wmc has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ml_in has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.hdhomerun has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.cy_gb has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in kodi.resource has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.af_za has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.uk_ua has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.hy_am has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.lt_lt has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.si_lk has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.vuplus has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.it_it has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.mythtv has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.mn_mn has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.ar_sa has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.tvshows.themoviedb.org has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.lv_lv has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in skin.pm3-hd has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.te_in has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in xbmc.pvr has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.nextpvr has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.amber has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.et_ee has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.omdbapi.com has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.he_il has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in pvr.hts has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in xbmc.codec has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.es_es has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Plug-in resource.language.be_by has been installed.'
15:55:32 T:6160773120 DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
15:55:32 T:6160773120 INFO: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BasePY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BaiduPY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian AZERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian QWERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian ЙЦУКЕН" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian АБВ" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Danish QWERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "French AZERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Arabic QWERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Czech QWERTZ" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Norwegian QWERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "German QWERTZ" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian ЯВЕРТЪ" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian АБВ" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Swedish QWERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Turkish QWERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Hungarian QWERTZ" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Romanian QWERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Spanish QWERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew QWERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew ABC" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Portuguese (Portugal) QWERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Greek QWERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Polish QWERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Korean ㄱㄴㄷ" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian ЙЦУКЕН" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian АБВ" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "English QWERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "English AZERTY" successfully loaded
15:55:32 T:6160773120 DEBUG: CKeyboardLayoutManager: keyboard layout "English ABC" successfully loaded
15:55:32 T:6160773120 DEBUG: Current resolution Screen: 0 with 3840 x 2160
15:55:32 T:6160773120 NOTICE: Found possible resolution for display 0 with 3840 x 2160
15:55:32 T:6160773120 NOTICE: Checking resolution 16
15:55:32 T:6160773120 DEBUG: About to switch to 3840 x 2160 on screen 0
15:55:32 T:6160773120 DEBUG: Found matching mode
15:55:32 T:6160773120 INFO: GLES: Maximum texture width: 2048
15:55:32 T:6160773120 DEBUG: EGL_EXTENSIONS: GL_OES_standard_derivatives GL_KHR_texture_compression_astc_ldr GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_pvrtc_sRGB GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_framebuffer_fetch GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_texture_filter_anisotropic GL_APPLE_clip_distance GL_APPLE_color_buffer_packed_float GL_APPLE_copy_texture_levels GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_texture_compression_pvrtc
15:55:32 T:6160773120 NOTICE: GL_VENDOR = Apple Inc.
15:55:32 T:6160773120 NOTICE: GL_RENDERER = Apple A10X GPU
15:55:32 T:6160773120 NOTICE: GL_VERSION = OpenGL ES 3.0 Metal - 52.1.1
15:55:32 T:6160773120 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
15:55:32 T:6160773120 DEBUG: GLES: Extension Support Test - GL_NVX_gpu_memory_info NO
15:55:32 T:6160773120 NOTICE: GL_EXTENSIONS = GL_OES_standard_derivatives GL_KHR_texture_compression_astc_ldr GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_pvrtc_sRGB GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_framebuffer_fetch GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_texture_filter_anisotropic GL_APPLE_clip_distance GL_APPLE_color_buffer_packed_float GL_APPLE_copy_texture_levels GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_texture_compression_pvrtc
15:55:32 T:6160773120 DEBUG: GLES: Extension Support Test - GL_EXT_texture_format_BGRA8888 NO
15:55:32 T:6160773120 DEBUG: GLES: Extension Support Test - GL_IMG_texture_format_BGRA8888 NO
15:55:32 T:6160773120 DEBUG: GLES: Extension Support Test - GL_APPLE_texture_format_BGRA8888 YES
15:55:32 T:6160773120 DEBUG: GLES: Extension Support Test - GL_EXT_unpack_subimage NO
15:55:32 T:6160773120 DEBUG: GUI Shader [guishader_frag_default.glsl]- Initialise successful : 0x1c4309ea0
15:55:32 T:6160773120 DEBUG: GUI Shader [guishader_frag_texture.glsl]- Initialise successful : 0x1c4309f30
15:55:32 T:6160773120 DEBUG: GUI Shader [guishader_frag_multi.glsl]- Initialise successful : 0x1c430a050
15:55:32 T:6160773120 DEBUG: GUI Shader [guishader_frag_fonts.glsl]- Initialise successful : 0x1c430a290
15:55:32 T:6160773120 DEBUG: GUI Shader [guishader_frag_texture_noblend.glsl]- Initialise successful : 0x1c430a320
15:55:32 T:6160773120 DEBUG: GUI Shader [guishader_frag_multi_blendcolor.glsl]- Initialise successful : 0x1c430a3b0
15:55:32 T:6160773120 DEBUG: GUI Shader [guishader_frag_rgba.glsl]- Initialise successful : 0x1c430a440
15:55:32 T:6160773120 DEBUG: GLES: Extension Support Test - GL_OES_EGL_image_external NO
15:55:32 T:6160773120 DEBUG: GUI Shader [guishader_frag_rgba_blendcolor.glsl]- Initialise successful : 0x1c430a4d0
15:55:32 T:6160773120 DEBUG: GUI Shader [guishader_frag_rgba_bob.glsl]- Initialise successful : 0x1c430a5f0
15:55:32 T:6160773120 INFO: GLES: Maximum texture width: 16384
15:55:32 T:6160773120 INFO: load keymapping
15:55:32 T:6160773120 INFO: Loading special://xbmc/system/keymaps/customcontroller.SiriRemote.xml
15:55:32 T:6160773120 INFO: Loading special://xbmc/system/keymaps/keyboard.xml
15:55:32 T:6160773120 INFO: GUI format 3840x2160, Display 3840x2160@ 59.94 - Full Screen
15:55:32 T:6160773120 DEBUG: guilib: Fill viewport on change for solving rendering passes
15:55:32 T:6160773120 INFO: CLangInfo: loading resource.language.en_gb language information...
15:55:32 T:6160773120 DEBUG: trying to set locale to en_US.UTF-8
15:55:32 T:6160773120 INFO: global locale set to C
15:55:32 T:6160773120 INFO: CLangInfo: loading resource.language.en_gb language strings...
15:55:32 T:6160773120 DEBUG: POParser: loaded 3780 strings from file resource://resource.language.en_gb/strings.po
15:55:32 T:6164213760 NOTICE: Running database version Addons20
15:55:32 T:6164213760 DEBUG: Initialize, updating databases...
15:55:32 T:6164213760 NOTICE: Running database version ViewModes6
15:55:32 T:6164213760 NOTICE: Running database version Textures13
15:55:32 T:6164213760 NOTICE: Running database version MyMusic60
15:55:32 T:6164213760 NOTICE: Running database version MyVideos107
15:55:32 T:6164213760 NOTICE: Running database version TV29
15:55:32 T:6164213760 NOTICE: Running database version Epg11
15:55:32 T:6164213760 DEBUG: Initialize, updating databases... DONE
15:55:32 T:6160773120 INFO: DPMS: not supported on this platform
15:55:32 T:6160773120 DEBUG: found key /userdata/modulepasswords.xml
15:55:32 T:6160773120 DEBUG: found key /userdata/addon_data/skin.mrmc/settings.xml
15:55:32 T:6160773120 INFO: Unloading old skin ...
15:55:32 T:6160773120 INFO: load skin from: /private/var/containers/Bundle/Application/FAA01914-30F8-49E9-A41F-FFE199E65F28/MrMC.app/AppData/AppHome/addons/skin.mrmc (version: 2.8.7)
15:55:32 T:6160773120 INFO: load fonts for skin...
15:55:32 T:6160773120 INFO: Loading fonts from /private/var/containers/Bundle/Application/FAA01914-30F8-49E9-A41F-FFE199E65F28/MrMC.app/AppData/AppHome/addons/skin.mrmc/720p/Font.xml
15:55:33 T:6160773120 DEBUG: POParser: loaded 150 strings from file /private/var/containers/Bundle/Application/FAA01914-30F8-49E9-A41F-FFE199E65F28/MrMC.app/AppData/AppHome/addons/skin.mrmc/language/resource.language.en_gb/strings.po
15:55:33 T:6160773120 INFO: Loading skin includes from /private/var/containers/Bundle/Application/FAA01914-30F8-49E9-A41F-FFE199E65F28/MrMC.app/AppData/AppHome/addons/skin.mrmc/720p/includes.xml
15:55:33 T:6160773120 INFO: load new skin...
15:55:33 T:6160773120 INFO: Loading user windows, path /private/var/containers/Bundle/Application/FAA01914-30F8-49E9-A41F-FFE199E65F28/MrMC.app/AppData/AppHome/addons/skin.mrmc/720p
15:55:33 T:6160773120 DEBUG: Load Skin XML: 3.93ms
15:55:33 T:6160773120 INFO: initialize new skin...
15:55:33 T:6160773120 DEBUG: guilib: Fill viewport on change for solving rendering passes
15:55:33 T:6160773120 INFO: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
15:55:33 T:6160773120 DEBUG: OpenBundle - Opened bundle /private/var/containers/Bundle/Application/FAA01914-30F8-49E9-A41F-FFE199E65F28/MrMC.app/AppData/AppHome/addons/skin.mrmc/media/Textures.xbt
15:55:33 T:6160773120 INFO: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
15:55:33 T:6160773120 INFO: Loading skin file: DialogKaiToast.xml, load type: LOAD_ON_GUI_INIT
15:55:33 T:6160773120 INFO: Loading skin file: DialogMuteBug.xml, load type: LOAD_ON_GUI_INIT
15:55:33 T:6160773120 INFO: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
15:55:33 T:6160773120 INFO: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
15:55:33 T:6160773120 INFO: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
15:55:33 T:6160773120 INFO: Loading resource://resource.uisounds.mrmc/sounds.xml
15:55:33 T:6160773120 INFO: skin loaded...
15:55:33 T:6160773120 DEBUG: JSONRPC: JSON schema type definition references an unknown type Setting.Details.Setting
15:55:33 T:6160773120 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
15:55:33 T:6160773120 INFO: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
15:55:33 T:6160773120 INFO: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
15:55:33 T:6160773120 INFO: JSONRPC v6.32.5: Successfully initialized
15:55:33 T:6160773120 DEBUG: ADDON: Starting service addons.
15:55:33 T:6160773120 DEBUG: Activating window ID: 12999
15:55:33 T:6160773120 DEBUG: ------ Window Init (Startup.xml) ------
15:55:33 T:6160773120 INFO: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
15:55:33 T:6160773120 NOTICE: ActiveAE DSP - starting
15:55:33 T:6160773120 INFO: removing tempfiles
15:55:33 T:6160773120 NOTICE: initialize done
15:55:33 T:6160773120 NOTICE: Running the application...
15:55:33 T:6160773120 DEBUG: Activating window ID: 10000
15:55:33 T:6160773120 INFO: GLES: Enabling VSYNC
15:55:33 T:6160773120 INFO: GLES: Selected vsync mode 10
15:55:33 T:6160773120 DEBUG: ------ Window Deinit (Startup.xml) ------
15:55:33 T:6160773120 DEBUG: ------ Window Init (Home.xml) ------
15:55:33 T:6160773120 INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
15:55:33 T:6164213760 DEBUG: CHomeShelfJob::UpdateMusic() - Running HomeShelf screen update
15:55:33 T:6164213760 DEBUG: CHomeShelfJob::UpdateVideos() - Running HomeShelf screen update
15:55:33 T:6160773120 DEBUG: NetworkMessage - Starting network services
15:55:33 T:6160773120 NOTICE: starting zeroconf publishing
15:55:33 T:6160773120 NOTICE: WebServer: Started the webserver
15:55:33 T:6164787200 DEBUG: CZeroconfOSX::doPublishService identifier: servers.webserver type: _http._tcp name:MrMC (Apple-TV) port:8080
15:55:33 T:6167556096 DEBUG: CZeroconfOSX::doPublishService identifier: servers.jsonrpc-http type: _xbmc-jsonrpc-h._tcp name:MrMC (Apple-TV) port:8080
15:55:33 T:6160773120 NOTICE: starting upnp client
15:55:33 T:6170996736 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
15:55:33 T:6170996736 NOTICE: UDP: Listening on port 9777
15:55:33 T:6160773120 INFO: JSONRPC Server: Successfully initialized
15:55:33 T:6160773120 DEBUG: CTCPServer: increasing thread stack to 1048576
15:55:33 T:6164787200 DEBUG: CZeroconfOSX::doPublishService identifier: servers.eventserver type: _xbmc-events._udp name:MrMC (Apple-TV) port:9777
15:55:33 T:6167556096 DEBUG: CZeroconfOSX::doPublishService identifier: servers.jsonrpc-tpc type: _xbmc-jsonrpc._tcp name:MrMC (Apple-TV) port:9090
15:55:33 T:6164213760 DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
15:55:33 T:6164213760 DEBUG: CHomeShelfJob::UpdateTotal() - Finished
15:55:33 T:6164787200 DEBUG: CHomeShelfJob::UpdateTotal() - Running HomeShelf home screen update
15:55:33 T:6164787200 DEBUG: CHomeShelfJob::UpdateTotal() - Finished
15:55:35 T:6179549184 DEBUG: UPNP: notfified container update upnp://RINCON_949F3E21ACEC01400_MS/R%3a/
15:55:35 T:6180696064 DEBUG: UPNP: notfified container update upnp://RINCON_949F3E14A86A01400_MS/Q%3a0/
15:55:35 T:6181842944 DEBUG: UPNP: notfified container update upnp://RINCON_949F3E043BA201400_MS/R%3a/
15:55:35 T:6161920000 DEBUG: CActiveAE - device change event
15:55:35 T:6161920000 DEBUG: EnumerateDevices:Device(default)
15:55:35 T:6161920000 NOTICE: Found 1 Lists of Devices
15:55:35 T:6161920000 NOTICE: Enumerated DARWINIOS devices:
15:55:35 T:6161920000 NOTICE: Device 1
15:55:35 T:6161920000 NOTICE: m_deviceName : default
15:55:35 T:6161920000 NOTICE: m_displayName : Default
15:55:35 T:6161920000 NOTICE: m_displayNameExtra:
15:55:35 T:6161920000 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:55:35 T:6161920000 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR
15:55:35 T:6161920000 NOTICE: m_sampleRates : 44100,48000
15:55:35 T:6161920000 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S16LE,AE_FMT_FLOAT
15:55:35 T:6161920000 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTSHD_CORE
15:55:35 T:6162493440 INFO: CActiveAESink::OpenSink - initialize sink
15:55:35 T:6162493440 DEBUG: CActiveAESink::OpenSink - trying to open device DARWINIOS:default
15:55:35 T:6162493440 DEBUG: virtual bool CAESinkDARWINIOS::Initialize(AEAudioFormat &, std::string &): AudioStreamBasicDescription: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz) pcm
15:55:35 T:6162493440 NOTICE: bool CAAudioUnitSink::setupAudio() setting channels 2
15:55:35 T:6162493440 NOTICE: bool CAAudioUnitSink::setupAudio() setting samplerate 48000.000000
15:55:35 T:6162493440 NOTICE: bool CAAudioUnitSink::setupAudio() setting buffer duration to 0.021333
15:55:35 T:6162493440 NOTICE: bool CAAudioUnitSink::setupAudio() total latency = 0.044500
15:55:35 T:6162493440 NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz)
15:55:35 T:6162493440 NOTICE: void dumpAVAudioSessionProperties() audio route = HDMIOutput
15:55:35 T:6162493440 NOTICE: void dumpAVAudioSessionProperties() sampleRate 48000.000000
15:55:35 T:6162493440 NOTICE: void dumpAVAudioSessionProperties() outputLatency 0.001833
15:55:35 T:6162493440 NOTICE: void dumpAVAudioSessionProperties() IOBufferDuration 0.021333
15:55:35 T:6162493440 NOTICE: void dumpAVAudioSessionProperties() outputNumberOfChannels 2
15:55:35 T:6162493440 NOTICE: void dumpAVAudioSessionProperties() maximumOutputNumberOfChannels 8
15:55:35 T:6162493440 DEBUG: DumpAudioDescriptions: void dumpAVAudioSessionProperties()
15:55:35 T:6162493440 DEBUG: DumpAudioDescriptions: input count = 0
15:55:35 T:6162493440 DEBUG: DumpAudioDescriptions: output count = 1
15:55:35 T:6162493440 DEBUG: DumpAudioDescriptions : portName, Apple TV
15:55:35 T:6162493440 DEBUG: DumpAudioDescriptions: channelLabel, 1
15:55:35 T:6162493440 DEBUG: DumpAudioDescriptions: channelName , Apple TV 1
15:55:35 T:6162493440 DEBUG: DumpAudioDescriptions: channelLabel, 2
15:55:35 T:6162493440 DEBUG: DumpAudioDescriptions: channelName , Apple TV 2
15:55:35 T:6162493440 DEBUG: CActiveAESink::OpenSink - DARWINIOS Initialized:
15:55:35 T:6162493440 DEBUG: Output Device : Default
15:55:35 T:6162493440 DEBUG: Sample Rate : 48000
15:55:35 T:6162493440 DEBUG: Sample Format : AE_FMT_FLOAT
15:55:35 T:6162493440 DEBUG: Channel Count : 2
15:55:35 T:6162493440 DEBUG: Channel Layout: FL,FR
15:55:35 T:6162493440 DEBUG: Frames : 1024
15:55:35 T:6162493440 DEBUG: Frame Size : 8
15:55:35 T:6162493440 DEBUG: CActiveAESink::GenerateNoise - noiseFactor = 0.000010
15:55:35 T:6161920000 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
15:55:35 T:6173814784 DEBUG: UPNP: notfified container update upnp://RINCON_949F3E14B1BC01400_MS/R%3a/
15:55:35 T:6173814784 DEBUG: UPNP: notfified container update upnp://RINCON_5CAAFD0F069C01400_MS/R%3a/
15:55:35 T:6173814784 DEBUG: UPNP: notfified container update upnp://RINCON_5CAAFDF79C6C01400_MS/R%3a/
15:55:37 T:6160773120 DEBUG: Activating window ID: 10025
15:55:37 T:6160773120 DEBUG: ------ Window Deinit (Home.xml) ------
15:55:37 T:6160773120 DEBUG: ------ Window Init (MyVideoNav.xml) ------
15:55:37 T:6160773120 INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
15:55:52 T:6160773120 INFO: Loading skin file: DialogMediaSource.xml, load type: KEEP_IN_MEMORY
15:55:52 T:6160773120 DEBUG: ------ Window Init (DialogMediaSource.xml) ------
15:55:55 T:6160773120 INFO: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
15:55:55 T:6160773120 DEBUG: found key /userdata/mediasources.xml
15:55:55 T:6160773120 DEBUG: ------ Window Init (FileBrowser.xml) ------
15:56:00 T:6167556096 DEBUG: SECTION:LoadDLL(libdsm.framework/libdsm)
15:56:00 T:6167556096 DEBUG: Loading: /var/containers/Bundle/Application/FAA01914-30F8-49E9-A41F-FFE199E65F28/MrMC.app/Frameworks/libdsm.framework/libdsm
15:56:00 T:6156759040 DEBUG: DllLibDSM:ns_discover_on_entry_added name(WHS2012ABS), address(192.168.0.18)
15:56:04 T:6160773120 INFO: Loading skin file: DialogNetworkSetup.xml, load type: KEEP_IN_MEMORY
15:57:37 T:6160773120 DEBUG: ------ Window Init (LockSettings.xml) ------
15:57:37 T:6160773120 DEBUG: CSettingsManager: requested setting (user.name) was not found.
15:57:37 T:6160773120 DEBUG: CSettingsManager: requested setting (user.password) was not found.
15:57:37 T:6160773120 DEBUG: CSettingsManager: requested setting (user.rememberpassword) was not found.
Post by davilla » 13 Dec 2017, 21:04
got a log from kodi ?
ganachain
Post by ganachain » 13 Dec 2017, 21:48
Kodi log connecting to the same server with the same smb://192.168.0.18/movies and same username/password with freshly downloaded Kodi "Krypton" 17.6 on my Mac.
On Mac Kodi there weren't any specific SMB settings to adjust like on MrMC
https://pastebin.com/cUhaCTkr
EDIT: forgot to turn on component specific logging below debug - above pastebin is with that off. Do I need to rerun with that on?
Post by davilla » 13 Dec 2017, 22:15
yes please. I think there is a component level for libsmb. Also, make sure you browse into the smb share.
ganachain
Post by ganachain » 14 Dec 2017, 02:25
turned on component logging - created the video folder, didn't assign to movies. Navigated into the folder after creation from Videos.
https://pastebin.com/xGhPdyc3
ganachain
Post by ganachain » 18 Dec 2017, 12:19
Anything else I can provide?
Post by davilla » 18 Dec 2017, 13:38
Your server is using SMB2 protocol. Which is not supported via libsmbclient or libdsm under iOS/tvOS. Not much we can do with either lib.
There are ways to re-enable it on your Windows server. Or move to using an NFS protocol.
We are working on a solution but that will not be ready until after the holidays.
se3mvp
Post by se3mvp » 20 Dec 2017, 01:48
Hey Davila, sorry I have been amiss with the comments, but I’m still having the same problem with loop backs using Smb. I even thought maybe I could switch to SFTP, but every time I enter the info into MrMc, it tells me that “the network server cannot be reached.”
Now something I thought about today that maybe is an issue or maybe not, Is that on my firestick in our downstairs room, I have mrmc app from amazon, and it is accessing the same files and such from my iMac on the first floor, that my Apple TV 4 on the first floor is accessing... is it possible that could be a potential issue?
I didn’t think of this before, because it was not an issue until Apple went to the High Sierra operating system, which got rid of FTP... I had both platforms accessing the files using FTP and it worked fine... but like I said earlier, I can’t even get either of them to access SFTP (which is the new “secure” ftp on High Sierra)
It seems like every time I get ready to post the logs on here, it all of a sudden works, but the day I don’t have the time to post the logs is when it gives me the username/password loop....
Users browsing this forum: timstephens24 and 4 guests
