SMB Username/Password Loop still happening
se3mvp
Post by se3mvp » 23 Nov 2017, 00:48
Hey guys, im STILL searching for answers, and I still have yet for anyone to answer my issue or help me. I have tried everything and yet im still stuck in the mud. After putting all of my permissions correct on my iMac running OS High Sierra, and sharing the folders I need on that side, I configured and added those folders via smb on MRMC. For a couple of days it worked, and yes I did turn on libdsm for smb servers, I did input user name and password when adding the share. but now, when I go to watch my movies, the lock preferences screen continuously pops up when I click on any of the folders im sharing from my iMac.
I put in the username and password of my iMac, and yet that screen just keeps looping, never accepting the credentials it seems. as of right now, I have everything shared thru zero config. but now even when I go back to look at the folders there, the lock preferences screen pops up and juts loops, no matter how many times I put in the credentials. I even tried to just share the folders thru windows smb. NO DICE. I have tried EVERYTHING.
SECURE FTP IS OUT AS WELL. That doesn't work PERIOD. Can someone provide me concrete solutions for this problem? If you read everything above, I have tried everything. IM AT A LOSS FOR SOLUTIONS.
Re: SMB Username/Password Loop still happening
Post by amet » 23 Nov 2017, 05:16
It really is difficult for anyone to assist with an issue we can’t reproduce :(
I have asked you for a debuglog before to see if anything stands out as an obvious issue.
For us it works, others have used “smbup” but I am not sure if it’s still supported on latest OS X
It sounds to me that you have not setup the library for your movies and only use folder structure... correct?
se3mvp
Post by se3mvp » 23 Nov 2017, 21:19
I apologize Ahmet if you asked for debug logs I probably missed it... Tell me how to turn on debug logs and then the proper way to post them and I will do so right away.... Thanks!
Post by amet » 23 Nov 2017, 21:46
It’s amet and click -> debuglog
se3mvp
Post by se3mvp » 23 Nov 2017, 22:40
Sorry Amet... and thank you... so to make sure I do it correct, I need to turn on debug, then tries to go thru the issue while it’s running, then once I’m done post that log?
Post by amet » 24 Nov 2017, 04:57
Yes please
ganachain
Post by ganachain » 12 Dec 2017, 23:00
I’m having exactly the same problem.
Difference is I’m trying to connect to Windows server 2012 R2.
I can get SPMC for Nvidia Shield Android TV to see the share and accept the password
I can get Kodi for Windows to see the share and accept the password
But When I put in the username /password I use for android and Windows fine, MrMC loops on it and won’t accept it.
I’m using the Server 2012 R2 essentials experience to add users and assign folder permissions.
If I turn on debug logging, how do I export the log to attach for you?
Post by davilla » 13 Dec 2017, 02:37
ganachain wrote:
12 Dec 2017, 23:00
Is Windows server 2012 R2 using smb1 or smb2 ?
ganachain
Post by ganachain » 13 Dec 2017, 03:00
SMB2
My Mac running Sierra can connect also with smb://
Post by davilla » 13 Dec 2017, 03:06
did you try libdsm or the default libsmbclient ?
also which MrMC platform ? iOS/tvOS or FireOS/Shield ?
