Movies not in the menu
bad_habit
Post by bad_habit » 08 Oct 2017, 14:02
I have the exact same problem described here and I can't find a solution: http://mrmc.tv/forum/viewtopic.php?t=245
Re: Movies not in the menu
Post by amet » 08 Oct 2017, 14:05
Solution mentioned didn’t help? Did you add movie source? What did you set it up as ? Do you have movies in individual folder and did you select that in the source settings?
Maybe debuglog has some info?
bad_habit
Post by bad_habit » 08 Oct 2017, 18:18
Thanks for the quick reply! I reinstalled and it showed up.
