FireOS 2.8.0 released
Post by davilla » 24 Nov 2016, 15:47
- fixed, segfault caused by not protected method CGUITextureManager::HasTexture
- refact, CBitstreamParser::FindIdrSlice so it works with both annexB and avcC formats
- removed, unused CBitstreamConverter::MaybeInterlaced
log m_lastIDRframe clamp correctly
- changed, tvOS. log what changed when screenDidDisconnect fires
- added latest ios devices for proper screen scale, thx Memphiz
silenced, debuging log spam in CDVDPlayerVideo
- fixed, tvOS. if we are paused when screensaver pops, come back paused unless we get pushed to background
- cosmetics, fixup comments in previous commit
- changed, move CheckForInterlaced to base class so we can use it in other demuxers
- fixed, used hints.maybe_interlaced to check for interlaced. using parseh264_sps cause false positive with rare h264i (finally found one :)
- changed, more robust CheckForInterlaced DVDDemuxFFmpeg
- sidestream sync, fixed, start at boot per app name. thx koying
- fixed, darwin/tvos typos
- sidestream sync, fixed use CLOCK_MONOTONIC, as OS. thx koying
-changed, ffmpeg makefile. 1) always build as release, 2) disable-vda, we do not use it under osx, 3) disable-runtime-cpudetect, we do explicit targetting, and 4) add arm64 build support
- changed, move back to full core usage under ffmpeg decode, no sign of previous deinterlacing issue
- fixed, mem/cpu usage logging under droid
- sidestream sync, droid arm Dyloader LP64 support
- fixed, tvOS. Downscale 4k to 1080p in h264 decoder to bypass memory bandwidth limit
refactor, tvOS MainController for better foreground/active/inactive/background handling
tweaks, buffers and friends in CDVDVideoCodecVideoToolBox
- fixed crash, music -> fullscreen. fake UnregisterAudioCallback better
- core: changed DVDVideoCodecAndroidMediaCodec drop/drain
- core: fixed h264/5.2 hw playback. remove ancient codec clamps in DVDVideoCodecAndroidMediaCodec
- core: silence depreciated warning on tvos/ios
- core: silence xcode warnings
- core: fixed ZebraListAccessCheck, need to compare paths using results from realpath, else they might not match
- tvos: topshelf image fix fro service based items
- core, CCurlFile::Download. add try/catch for internal throws that can crash us and move to direct to file. fixed crash on downloading large files'
- core, bump up render buffers for osx
core, speed up CUtil::GetFileAndProtocol by a factor of three
- core, increase the read size for CUtil::GetFileMD5
- changed, plex client. use g_sysinfo.HasInternet and fallback to PingHost to plex.com for checking internet access
- added, debug setting to periodic log app memory/cpu usage
- show Load profile window from settings submenu, Profile setup needs to be done in Settings -> profiles
- fixed, hack in fix for sierra/osx libcurl
- fixed crash, plex client. defer GetDefaultHeaders until we have a network
- fixed, tvOS crash when in background. do not render if we cannot
- fixed, exclude dvd/stills from DVDVideoCodecAndroidMediaCodec. Always set m_videobuffer.pts so dvdplayer knows. thx koying
- fixed, jpegio. return original size, thx koying
- DVDOverlaySSA: Fix Leak with SSA subtitles
- GUIFontTTFGL: Fix texture leak in subtitles
- cosmetic cleanup, no functional change
- plex: fix listing of shows/movies if only one content section exists.
- skin.amber: hide music , tvshow and movies if user so chooses.
- fixed, another message memleak in ActiveAE
- upstream sync, rar deadlock with cbr + net vfs #10830
Most noticeable is addition of IEC/non-IEC passthrough selection in settings as some fireOS devices prefer IEC format, others prefer non-IEC.
eXiNFeRiS
Re: FireOS 2.8.0 released
Post by eXiNFeRiS » 25 Nov 2016, 00:17
Great Work, DD AC3 Passthrough finaly works again (On my old Hardware) after this Update. BIG THX. :D :D :D
gogito75
Post by gogito75 » 13 Dec 2016, 17:16
Does not work well with me! LiveTV mpeg2, H264 does not work smoothly! I sent a mail log file! I expect to be fine in the next update :)
Post by davilla » 13 Dec 2016, 17:24
gogito75 wrote:Does not work well with me! LiveTV mpeg2, H264 does not work smoothly! I sent a mail log file! I expect to be fine in the next update :)
debuglog please
Post by davilla » 13 Dec 2016, 20:02
Should be fixed when 2.8.1 gets released. Which is pending a few more days of testing.
