Boblight/Ambilight clone anyone?
Post by amet » 05 May 2016, 14:34
Just a quick post to check how many/if any of you use boblight/ambilight clone. It has been integrated as core feature in MrMC now and we are doing final testing. if all is okay we will include it in next version for AppleTV/FireTV and maybe even iOS, not sure we want it on iOS but there is no technical limitation to it.
of course, you would need a boblight server on a separate machine(rpi, some routers... etc) and a LED setup with arduino to get it going, we have only included the client part that was lost once we removed python.Communication with the server is done via LAN and there is no way to plug arduino directly into AppleTV or FireTV.
more on it below....
https://en.wikipedia.org/wiki/Ambilight
http://www.instructables.com/id/30-chan ... ght-Clone/
http://www.schrankmonster.de/2014/01/12 ... i-raspbmc/
Re: Boblight/Ambilight clone anyone?
Post by timstephens24 » 05 May 2016, 16:43
I have white LED strips behind my TV but this seems "better"... Would probably use this after I get it setup now that I know about it.
Post by koying » 07 May 2016, 08:34
I don't know if it's used a lot with Kodi, but don't forget Philips Hue.
If you have boblight, only the server api changes, afaik (as the addon is basically a clone of it).
ameibein
Post by ameibein » 14 Aug 2016, 08:27
Is there a guide on what hardware to buy for this?
bogchop
Post by bogchop » 02 Nov 2016, 05:17
I have a Lightpack that I currently use with LibreELEC - looking to use it here as I've just bought a new ATV4.
How would I go about doing it? Seems like I need to run boblightd elsewhere - I run a RPi3 with RetroPie, or I have a 24/7 server running WHS2011.
Any guides/point in the right direction would be appreciated.
Thanks,
bc.
Post by amet » 02 Nov 2016, 05:50
You should be able to run boblight on rpi3
Not sure how lightpack interacts with libreelec, if it's boblight then it should be okay.
joelpref
Post by joelpref » 14 Nov 2016, 19:49
Just digging into features with the MrMC app, and looking at doing Philips Hue LED Strip lighting around tv.
Has anyone had success using Hue with the LighEffects add in ?
http://www.aftvnews.com/wp-content/uplo ... ptions.jpg
Any feedback is appreciated , as its an expensive investment to buy 5 meters of lighting. thanks!
Post by amet » 15 Nov 2016, 05:42
I am using boblight setup , I believe Hyperion setup is compatible with it as it can act as boblight server.
Not sure about Philips HUE , haven't tried it
joelpref
Post by joelpref » 15 Nov 2016, 13:53
thanks, and when watching movies, the delay is correct and displays close to the patterns on the screen ?
I think ill go with the Hue strip lights on the back of the tv as the quality is higher. expensive , but lots of ifttt integrations as well.
Post by amet » 15 Nov 2016, 14:02
yeah, all matches the screen colors here...
as I said, not sure if we can drive the Hue, I didn't try it
