MrMC v3.0.2 on tvOS
MrMC v3.0.2 on tvOS
Post by davilla » 16 Mar 2017, 18:30
add ShowCodec to virtual remote in Webui
fixed, plex. correctly display partially watched episode when “unwatched” filter is applied
fixed, missing CURL::GetRedacted
fixed, skin.mrmc. lost “programs” menu. if disabled, it cannot be enabled
changed, enable file caching for bluray m2ts files
fixed, enable YADIF, YADIF-half for arm/arm64
fixed, file/cache buffering issues
ajseesink
Re: MrMC v3.0.2 on tvOS
Post by ajseesink » 16 Mar 2017, 20:48
Good job 👍🏻
Got one problem with 3.0.2 that was 't there before.
I've got massive sync problems. Happens with all formats I play.
Iinfuse and DS Video doesn't have those problems. Previous versions of MrMc played it correct also.
Playing movies or series on a ATV, connected with hdmi on tv. Tv is connected with fiber optics to a stereo receiver.
Andre
Post by timstephens24 » 16 Mar 2017, 23:56
I'm not seeing any sync issues. What are you playing?
Post by cosmoxl » 17 Mar 2017, 02:05
I haven't tested but one mkv rip from blu-ray, but there were no problems.
I output muti channel PCM with sync to display on. Audio offset in MrMC is 0 (zero) ms.
I output to receiver, then to TV.
Post by davilla » 17 Mar 2017, 03:01
as always, debuglog please.
Everbrave
Post by Everbrave » 17 Mar 2017, 12:04
I cannot report any issues (yet) except:
1) Siri remote is still very sensitive (really irritating!)
2) no new "MrMC worthy" skins; still waiting for the Dark-mode in SiO2
thanks
ameibein
Post by ameibein » 17 Mar 2017, 14:06
Any idea when or if Estuary Skin will be included with MrMC? Keen to check it out :)
Post by cosmoxl » 17 Mar 2017, 14:17
Everbrave wrote:
17 Mar 2017, 12:04
thanks
it sounds like you have the siri remote option turned on (settings>system>input devices). That has never been to my liking. Have you tried just turning that off and tapping (not clicking) the edges of the remote to get around? It's actually very fast once you get used to it. See the video that ameibein posted in another thread.
Post by amet » 17 Mar 2017, 15:11
ameibein wrote:
17 Mar 2017, 14:06
It will it happen, we have discussed this already
Everbrave
Post by Everbrave » 18 Mar 2017, 00:38
cosmoxl wrote:
17 Mar 2017, 14:17
Everbrave wrote:
17 Mar 2017, 12:04
thanks
Much better this way, thanks!
