Botched open subtitles in iOS
Any issues relating to subtitle search and download function
Looxoor
Post by Looxoor » 20 Feb 2016, 01:54
I entered incorrect login info in the prompt and since then there's always zero found when I search.
Is there any way to reenter the info?
Re: Botched open subtitles in iOS
Post by amet » 20 Feb 2016, 04:05
Hm, there is an issue with that skin..:. I'll fix that for future versions, to fix the issue now you can switch skin to MrMC(confluence) in settings ->appearance -> skin and start the subtitle search, in the window that appears you will see a button to change login details
Looxoor
Post by Looxoor » 20 Feb 2016, 09:02
amet wrote:Hm, there is an issue with that skin..:. I'll fix that for future versions, to fix the issue now you can switch skin to MrMC(confluence) in settings ->appearance -> skin and start the subtitle search, in the window that appears you will see a button to change login details
Thanks!
That worked perfectly!
Post by amet » 20 Feb 2016, 14:49
Great, will be fixed for next iOS
Thanks for finding it :)
