Testing MrMC 3.5.1
Testing MrMC 3.5.1
Post by davilla » 13 Feb 2018, 14:23
How to request Testflight access: Send an email to support@mrmc.tv with the subject "I see dead people", include your forum username and email address tied to device, and which flavor (tvOS, iOS, Amazon or GooglePlay). Users that are already in testflight 3.3.x are already in this series.
Pending for iOS.
Released for tvOS.
Pending for Amazon.
Pending for GooglePlay.
For GooglePlay Beta Open Testers only, https://play.google.com/apps/testing/tv.mrmc.mrmc.lite
(180221.20 @20180220-a3d3a34)
backport: Double the backslash in mysql in case we're in 'LIKE'
testing: increasing logging for naming convention thread
core: add quantizing for 23.976 fps under appletv4
tvos: - try to really ignore interlaced content on hw decoders
core: add monitor for tvOS interface environment changes
core: changed yuv/rgb matix values for 601/709
fixed: tvOS UIView/Alpha using AVSampleBufferDisplayLayer
fixed: Long Hold select to bring a list of PVR channels
skin: latest blackglassnova
fixup OSDSettings localized strings for 3D submenu
skin: opacity, added gray colour scheme
plex: fix in progress sort order, it was broken for so loooong :)
(180222.1734 @20180222-4462bdb)
core: add zoom, stretch, non-linear stretch, vertical shift and pixel ratio to CDVDVideoCodecAVFoundation
core: change thumbs to not use file caching, fix possible format errors
core: changed rapidjson to use iterative instead of reentrant parsing to avoid stack overflows
core: remove stack doubling for tvOS, stack overflow vanished with move to rapidjason
core: add show OSD Settings on swipe down if playing fullscreen video
core: more fixes, tvOS UIView/Alpha using AVSampleBufferDisplayLayer
(180303.1456 @20180302-16ace80)
fix double left/right click command with IR remote, visible only in full screen playback non expert mode
add network drives to favourites window, users were unable to set thumbs for favourite items
skin: update skin.blackglassnova
fixed: photo nav under tvOS
(180306.2227 @20180306-60f7e58)
core: fixed missing folder.jpg items, file buffering has nothing to do with dir cache pre-load for getting folder thumbs
(180317.4 @20180316-23dabe6)
core: return of python
core: add 'plex for kodi' addon
core: check for bogus avg_frame_rate (mkv) before trusting it
core: fixed gif open error, helps to open only once
(180318.1414 @20180317-8814451)
core: paranoid checks for null or empty property key values
core: add mrmc-scrips (with script-plex, script.module.requests) to depends
(180319.317 @20180318-05a881c)
core: fixed possible crash with tvOS focus engine, need locks to cross threads
core: ignore window/dialog when making UIViews (tvOS focus), they are huge and suck down ram memory of atv4k
core: use kCAContentsFormatGray8Uint for focus UIViews, they consume less memory than kCAContentsFormatRGBA8Uint
( 180320.1459 @20180320-d59314c)
fixed: search for plex for kodi
fixed: Use menu to stop video playback under expert mode
depends: libffi: fix arm assembler syntax
(180321.1936 @20180321-84871bc)
plex: fix parsing of only one show in ParsePlexSeries
core: remove unused functions
droid: better notif icon
droid: android colors
droid: change download fallback location for oob files
droid: don't send frames before render is ready
darwin: fixed iOS dim bug, screen scaling was wrong
darwin: fixed iOS mirroring
darwin: ARC is nice but we want these release ASAP please, so wrap them in an autoreleasepool
darwin: fixed possible crash with tvOS focus engine, need locks to cross threads
darwin: drop building for 32 bit OSX
depends: fixed build for droid
(180323.1058 @20180323-d4ced22)
revert core: ignore window/dialog when making UIViews
(180323.2157 @20180323-8528a21)
darwin: force gles to RGBA8 on wide color devices
core: rework hdr detection and stop using magic numbers for color primaries, range, etc
(180324.2130 @20180324-4dfa7ce)
fixed GUIinfomanager reporting of TVOS platform
plex addon: allow script.plex to go directly to TVOS Home
(180325.1604 @20180325-f888d34)
darwin: focus, fix possible crash if python based window/dialog is deleted
core: fix possible crash coming from python if key is null or empty
core: change busydialogdelayms to 1000ms default with range of 0 to 4000ms
SUPERBIF
Re: Testing MrMC 3.5.1
Post by SUPERBIF » 13 Feb 2018, 14:59
Hi. When using the OSD channel guide in Live TV it doesn't go away automatically after switching to a channel.
Is that something that can be changed.
Post by davilla » 13 Feb 2018, 15:09
SUPERBIF wrote:
13 Feb 2018, 14:59
which skin ?
SUPERBIF
Post by SUPERBIF » 13 Feb 2018, 18:27
Amber
Post by amet » 13 Feb 2018, 19:18
tried other skins? its skin related
Ted377
Post by Ted377 » 13 Feb 2018, 19:38
Did you notice that the CPU usage is over 100% as soon as you watch a TV program in HD?
When I watch a movie about Plex the load is at max. 60%.
Post by cosmoxl » 13 Feb 2018, 19:45
Ted377 wrote:
13 Feb 2018, 19:38
Live TV/DVR of broadcast mpeg2 or interlaced h264 uses software decoding so is taxing the CPU. Other playback likely uses hardware decoders so you'll see much less CPU usage.
If you also use software deinterlacers (yadif) the CPU usage goes even higher!
sdsnyr94
Post by sdsnyr94 » 14 Feb 2018, 15:41
Received 3.5.0 on my Shield last night. I'm still having issues getting HDR to function properly.
Post by cosmoxl » 14 Feb 2018, 19:48
Looks like 3.5.1 is out for tvOS?
Itzme1234
Post by Itzme1234 » 14 Feb 2018, 21:25
Yes. The note is "Plex; fix in sort order" I've updated and tested some.
