(180111.1711)
siri: add SiriSelectHandler in addition to SiriLongSelectHandler
darwin: clean up some logging in MainController
darwin: fixed tvOS native keyboard and leaky menu/back
opacity: disable quit menu in profiles screen
fixed, block skins from issuing an exit under darwin. not permitted
Testing MrMC 3.4.1
Re: Testing MrMC 3.4.1
https://gist.github.com/anonymous/c2409 ... 4f5d9623b5
Sorry, installed the latest build, played OTA live TV, went to audio settings, pressed menu and boom, out of the app.
This is the "old" log, figured it might have caught something.
Was this a crash or normal menu backing out to tvOS home ? You can tell different by how MrMC splash behaves. Or from the debuglog.cosmoxl wrote: ↑11 Jan 2018, 18:43 https://gist.github.com/anonymous/c2409 ... 4f5d9623b5
The fixes involved spurious menu backing out to tvOS home. Crashes are a different thing.
https://gist.github.com/anonymous/52900 ... 24f45a0beddavilla wrote: ↑11 Jan 2018, 18:53Was this a crash or normal menu backing out to tvOS home ? You can tell different by how MrMC splash behaves. Or from the debuglog.cosmoxl wrote: ↑11 Jan 2018, 18:43 https://gist.github.com/anonymous/c2409 ... 4f5d9623b5
here's the next log which is when I opened MrMC after the previous log. How can I tell if it was a crash or back out to home? What should I look for in the splash screen?
old -> 12:40:45
new -> 12:41:02
About 15 seconds apart, the fact that log rolled means crash.
It will wait at Splash longer on a real start up. Also app out -> in will put you back in the same place.
new -> 12:41:02
@cosmoxl sounds familiar ? https://github.com/kodi-pvr/pvr.dvblink/issues/69
as you may have searched this forum and realized, I do use dvblink.davilla wrote: ↑12 Jan 2018, 03:21 @cosmoxl sounds familiar ? https://github.com/kodi-pvr/pvr.dvblink/issues/69
I'm not sure I can answer your question without that thread being translated to language that has meaning to me...or maybe you were just being hypothetical. I don't know anything about getbuffertime start, etc.
with dvblogic closing the thread, I wonder if they've updated the add-on to fix the crash?
3.4.1 (180113.440)
- more Siri remote fixes
- fake uisounds addon to allow for tvOS native sounds
Just 1 minute ago. It's working again. Thank you so much, amet!
