Cursor Accessibility
Moderator: pecinko
barong
Post by barong » 01 Dec 2018, 11:58
TVOS has an accessibility option that makes the cursor stand out more / high contrast.
This puts a border around the currently selected item. If enabled it is system wide as well as certain other apps like Netflix etc.
I was wondering if something like this could be added to Ariana? May help people like me with vision impairments.
Info here:
https://www.apple.com/au/accessibility/tv/vision/
Thanks in advance.
pecinko
Re: Cursor Accessibility
Post by pecinko » 01 Dec 2018, 13:01
Happy to help you about this.
Please explain what you need in more detail as I have no experience with this.
barong
Post by barong » 01 Dec 2018, 23:17
Cool, thanks for the prompt reply.
This link is a few years old but shows how to enable the setting and how it looks.
https://www.idownloadblog.com/2015/11/1 ... -apple-tv/
Basically it puts a white border around the currently selected item in addition to the standard raised effect.
If you enable this setting in TVOS itself you can see how it works on the home screen for reference.
pecinko
Post by pecinko » 02 Dec 2018, 12:35
Thanks. This will take a bit of time to implement and will have to wait for ver 3.8
barong
Post by barong » 03 Dec 2018, 06:55
Thanks for looking into this - much appreciated
