(Bug?) Startup window: TV - Launches to black screen
Moderator: pecinko
PlatypusW
Post by PlatypusW » 29 Sep 2018, 22:16
On tvOS:
If I set the startup window setting to 'TV', I was expecting the app to launch to 'TV Shows' (is this correct?) but instead I get a black screen. Thinking about it, I'm not sure if this is meant to be 'live tv/dvr' or something as I don't see a movies option either.
If I then go back (press menu) I get the home window. It seems like the app is launching to something unknown and just displaying a black screen? Does anyone else have this problem? Potentially its launching to 'Live TV/dvr' which isn't set up?
I would really like it if there was a way to launch the app straight to 'TV Shows' or 'Movies' if this wasn't the intended feature.
Re: (Bug?) Startup window: TV - Launches to black screen
Post by cosmoxl » 29 Sep 2018, 22:37
PlatypusW wrote:
29 Sep 2018, 22:16
On tvOS:
TV is different from "TV shows". Sounds like it's launching to live tv/dvr as you surmise.
pecinko
Post by pecinko » 29 Sep 2018, 22:53
Indeed, TV opens up "Live TV/PVR".
Closest to what you probably want is "Videos", which opens up video library.
PlatypusW
Post by PlatypusW » 30 Sep 2018, 13:24
Thanks, seems like it isn't a skin issue and appears to be an MrMC system setting. Sorry for posting in the wrong section :)
