Favourites and Filtering
Moderator: pecinko
DocEagle
Post by DocEagle » 20 Sep 2018, 07:36
Using the Ariana skin I can‘t find the icon for Favourites any more.
Where do I find the option for searching/filtering the db records?
pecinko
Re: Favourites and Filtering
Post by pecinko » 20 Sep 2018, 08:27
Favourites are off by default so you probably need to enable them in skin settings. There's a new feature in version 3.7, available via context menu, allowing you to add most items directly to a home menu. Maybe it will suit you more.
Filtering by letter did not make it to this version of Ariana, but will be added soon. Other filter/sorting options are available in top menu.
DocEagle
Post by DocEagle » 20 Sep 2018, 10:24
pecinko wrote:
20 Sep 2018, 08:27
I'm a little bit confused. I found the option in the context menu and added a special folder to the home screen, but I don't see the folder there ...
Trying again I get the option to remove it, i. e. the adding obviously worked. But how can I make it visibile?
pecinko
Post by pecinko » 20 Sep 2018, 10:34
Should be there in that case, added at the end of main menu, after the usual items (movies, tv, music etc)
DocEagle
Post by DocEagle » 20 Sep 2018, 11:13
Thought so, not in my case. I add a folder, but the main window looks like before. I never had a QUIT button in an Apple TV environment.
DocEagle
Post by DocEagle » 20 Sep 2018, 11:30
How did you get the FAVOURITES icon to your home window? This was my actual question.
Now I got it. I interpreted the button as a heading - my fault.
But the topic above (adding a folder to the home window) isn't resolved yet.
pecinko
Post by pecinko » 24 Sep 2018, 12:33
I have added filtering/search for future version.
DocEagle
Post by DocEagle » 25 Sep 2018, 20:50
Great news, thank you for this!
I really like the Ariana skin.
