tvOS - Back to go back ? Topic is solved
Moderator: pecinko
Morien
Post by Morien » 18 Sep 2018, 15:42
Hey,
I really like the look of the new skin and was really looking forward to today's release, but on tvOS it needs a bit of tweaking. (Or perhaps I'm missing something and would gladly be informed).
On more traditional skins on 3.6.2 if I was in a folder, eg. Movies, I could press left to pull out the drawer and sort movies, show only unplayed, or update the library. If I pressed back, it would go back a level. I don't think I used the drawer ever beyond the initial setup, but it being there didn't hurt. "Back" though, I used constantly. Now, if I press back it pulls out the drawer (now at the top), and to actually go back I have to press back a second time.
Can I change this behaviour to just have back go back?
Thank you
mrfahrbot
Re: tvOS - Back to go back ?
Post by mrfahrbot » 18 Sep 2018, 17:36
Agreed. This feels too clunky- after initial setup I practically never need to access it so having to go through it constantly is a pain.
Post by timstephens24 » 18 Sep 2018, 20:49
I rather like Ariana the way it is. It's more like other apps on the Apple TV and I use that section a lot.
Nik3sh
Post by Nik3sh » 19 Sep 2018, 00:25
Personally I think when you’re at the top row in the movie/tv folder(library) you should be able to swipe up, on the remote, to bring out the menu options then swipe down to make it disappear just like the Plex app, instead we have the case having to press menu twice to back out which is annoying.
Morien
Post by Morien » 19 Sep 2018, 00:29
Would be great if behaviour of the button would be user selectable, much like the way you can choose the default action of playing a movie (play, resume, information, or ask) or whether to use the Siri trackpad features of the remote or not.
pecinko
Post by pecinko » 20 Sep 2018, 08:29
Thanks for feedback. I will consider possible improvements here.
Morien
Post by Morien » 20 Sep 2018, 10:02
What a great response! Thanks, a lot!
barong
Post by barong » 21 Sep 2018, 00:38
+1 for this behaviour. I also bought this up during the Test Flight.
Pressing back should take you back a screen as the current behaviour differs from almost every other skin/app on the platform.
Besides from that pecinko has done a great job on this skin :)
Waltman
Post by Waltman » 21 Sep 2018, 09:12
+1 for changing this behaviour.
pressing back should take you back a screen as the current behaviour differs from almost every other skin/app on the platform. xvmc / kodi has always used un up/down or left right command.
overall : i love the skin you made !
pecinko
Post by pecinko » 24 Sep 2018, 12:32
I have changed BACK button action for future version.
