Shield TV remote functionality
biodtl
Post by biodtl » 06 Dec 2018, 23:26
I transitioned from SPMC and miss the way the Shield TV remote use to work. I am using the Ariana skin. Maybe I am missing some other way to configure this. Here are the 2 issues I have, that really make it difficult for visitors and less technical people to use:
When navigating a media library with multiple sub-folders, the "Back" button on the remote brings up a "View, List, Sort By, Order By" menu. I simply want it to go up a level in the directory structure.
During playback, I would like a short press on the large round button to pause, and another short press to resume. This is currently handled by a long press. Can I somehow switch the short and long press functions?
Jxplex
Re: Shield TV remote functionality
Post by Jxplex » 09 Dec 2018, 21:50
you can definitely do the first with the keymapper addon. The second, may be doable too. The issue is it's bugged on the current release. My fix was to set my desired keymap in spmc then copy the xml file over to mrmc
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
