MrMC Lite Test on Shield - Vertical Shift and AV Sync
jcwillia1
Post by jcwillia1 » 02 Dec 2018, 15:44
I was thrilled to finally find a player that supports vertical shift on the Shield. I have a strange home theater set up and without the vertical shift feature, my home theater experience is really bad for the back row.
For whatever reason, the Krypton release of Kodi has broken vertical shift and Leia eliminates it altogether.
Anyways, as I was testing this with some 4k rips (Last Jedi, Matrix, Avengers) I immediately noticed that the AV sync was pretty awful. I saw some other posts on other fourms saying the same thing so I know it wasn't just me.
Is there an older version of MrMC that I can side load that will support vertical shift and does not have AV sync issues?
Re: MrMC Lite Test on Shield - Vertical Shift and AV Sync
Post by davilla » 02 Dec 2018, 19:19
jcwillia1 wrote:
02 Dec 2018, 15:44
Pending 3.7.1 fixes a/v issues.
Sorry but we do not support side loading of MrMC or MrMC-Lite.
jcwillia1
Post by jcwillia1 » 02 Dec 2018, 22:46
jcwillia1 wrote:
02 Dec 2018, 15:44
Thanks for response
Any vague idea on timing of that?
