How do you enable Channels and Play Next?
KnifeFed
Post by KnifeFed » 21 Sep 2018, 04:33
I got the 3.7.0 update today, but MrMC isn't listed in "Customize channels" or "Play Next". I can't seem to find anything pertaining to this in the MrMC settings either.
thesuffering
Re: How do you enable Channels and Play Next?
Post by thesuffering » 21 Sep 2018, 16:17
According to Koying, this is how you do it:
https://forum.kodi.tv/showthread.php?tid=332589
Problem is, I cant seem to make this work. Does this work if you use the Plex client? Nothing is populated in my smart playlist and nothing shows up in the channels section of Android TV
Post by koying » 21 Sep 2018, 16:39
No. Smart playlists (and thus custom channels) only work when using a local database.
KnifeFed
Post by KnifeFed » 21 Sep 2018, 18:38
I created a media resource and added some videos, to get a local database. I then created a playlist containing a bunch of those videos. I still couldn't see any channels from MrMC, so I rebooted. Didn't help. I then cleared data for the launcher. Didn't help.
I guess it doesn't really matter any way for me, since I only use MrMC with the Plex extension.
thesuffering
Post by thesuffering » 21 Sep 2018, 19:54
koying wrote:
21 Sep 2018, 16:39
Is this something that could possibly be added in a future update or is it just too much of a PITA since its not a local database. The downright simple Plex integration is one of the biggest reasons I use MrMC, but Id love to see Channel support from plex service as well.
Post by koying » 21 Sep 2018, 23:48
I guess smartplaylist support *could* be developed for the internal Plex support of MrMC (@davilla ?) but certainly not if you're using the extension...
whinette
Post by whinette » 22 Sep 2018, 09:03
Since yesterday I have mrmc channels, I did not when I initialy installed the new release though.
This is handled weirdly, the art is not loaded for most of the show and lists are just the firts items of my plex library, except for the suggestions one.
Fehritale
Post by Fehritale » 03 Oct 2018, 19:15
I have both Kodi Beta and MrMC installed.
MrMC is showing the exact same channels as Kodi.
In Kodi i have serveral smart playlists, all working fine and showing as channel. The smart playlist created in MrMC is not showing as channel. But MrMC is showing the Kodi channels.
Is it a known bug?
Fehritale
Post by Fehritale » 11 Oct 2018, 18:36
The beta update to 3.7.1 did not fix it. MRMC and Kodi are showing exactly the same channels.
Post by koying » 11 Oct 2018, 20:44
That's because they use the same port for json-rpc.
If you exit both, then launch MrMC first, you'll see that Kodi shows MrMC content.
