MrMC missing from Play Store
thesuffering
Post by thesuffering » 20 Sep 2018, 22:59
Went to go update to 3.7 and couldnt find it on the Play store on my Shield (2017). Went to the website, and while its there, it says "This item is not compatible with your device" . How do I fix?
I do have 3.6-2 installed, and it was from Play Store originally.
Re: MrMC missing from Play Store
Post by koying » 21 Sep 2018, 00:15
Have you unlocked your bootloader and/or rooted your shield?
thesuffering
Post by thesuffering » 21 Sep 2018, 00:23
Yes, but it was available before. Is it only available if you are unrooted/locked? Did that change?
thesuffering
Post by thesuffering » 21 Sep 2018, 16:20
I went ahead and relocked the bootloader. It did wipe all my data, which is a pain. MrMC shows up fine now in the Play store. I had rooted to be able to do PS4 Remote Play, but I rarely use that. At least now MrMC updates :D
rodalpho
Post by rodalpho » 23 Sep 2018, 18:40
Wait, I can't use MrMC with an unlocked bootloader?! Even though my device is not rooted?
Surely that is a mistake. I can't imagine why it would be necessary when banking apps and Netflix work fine when unlocked. I immediately unlock the bootloader on all my Android devices because Android wipes ALL your data when you do it. I have no intention of relocking to run this app. I prefer it to Kodi, but not to that degree.
If that really is the problem, I hope you change your minds quickly. And If not, I believe a refund is reasonable. Who do I contact for a refund?
