Plex background
Tazg101
Plex background
Post by Tazg101 » 20 Sep 2018, 19:16
Since the new update. The background in plex is the movie or tv wallpaper. This looks messy and if the wallpaper is white. Text is unreadable and the image is too bright. Is there anyway to go back to the old static image? Thanks
Itzme1234
Re: Plex background
Post by Itzme1234 » 20 Sep 2018, 21:22
I’m seeing that issue also.
KnifeFed
Re: Plex background
Post by KnifeFed » 21 Sep 2018, 04:06
I assume you're talking about the Plex extension (not the built-in functionality), because I'm experiencing problems with it too.
This is what the Home screen for the Plex extension looks like:
Everything normal so far.
This is what it looks like after I've started playing a video, making the "Continue watching" section appear:
The thumbnail is just a blur.
If I go to the info for the movie, I get this:
Looks normal.
If I regenerate thumbnails (Settings -> Appearance -> Cached Images -> Regenerate thumbnails), I get this on the Home screen:
The thumbnail looks like it should, but it seems to be using the same image for the background, except without the blur effect.
The movie info screen now looks like this:
Again; low-res background image without blur.
If I start playing another video, then go back to the Home screen, I get this:
...and the info screen for that movie looks like this:
Looks normal.
If I regenerate thumbnails again, the Home screen looks like this:
...and the info screen looks like this:
And so on, and so on...
Tazg101
Re: Plex background
Post by Tazg101 » 21 Sep 2018, 18:17
Yes. Same issue for me.
If I have a mainly white background image. The image is blinding. Can’t read text either.
whinette
Re: Plex background
Post by whinette » 22 Sep 2018, 08:58
Thanks for the long description @KnifeFed, I also have this issue.
TBH, I'm not against fanart for background if it was handled better (shadowing box for text, better resolution for fanart).
shage1
Re: Plex background
Post by shage1 » 23 Sep 2018, 13:32
Having the same issue as well
Re: Plex background
Post by amet » 23 Sep 2018, 19:16
It’s Plex Addon issue, and it has been fixed...
viewtopic.php?f=28&t=4418#p20417
Users browsing this forum: Bing [Bot] and 4 guests
