hue sync help
rohazon
hue sync help
Post by rohazon » 19 Sep 2018, 08:07
hello,
I just setup today MrMc on my 2015 Shield (latest firmware) and I'm now trying to get my hue lights to sync.
In settings, I was able to pair bridge and added 2 lights as ambilight mode (i have 2 hue go lights)
When i launched a movie, my lights were already ON ; MrMc switch color once and then lights keep fix color, no changed.
i did check the wiki / forum but couldn't find anything relevant.
can anyone help me out please.
Thanks and enjoy your day
Rohazon
notlbishop
Re: hue sync help
Post by notlbishop » 19 Sep 2018, 08:48
was this on a 4k movie? I am seeing similar behaviour on appletv. i think this might work ok on 1080 but for some reason i never seem to get a response from anyone around here.
rohazon
Re: hue sync help
Post by rohazon » 19 Sep 2018, 10:05
i only play 1080p (or 1080i) file.
do you know if i need to give logs ? if yes, is it as for spmc/kodi to pull logs out?
notlbishop wrote:
19 Sep 2018, 08:48
Re: hue sync help
Post by koying » 19 Sep 2018, 19:09
The 4K issue is specific to ATV. This is Shield.
See https://wiki.mrmc.tv/index.php/Debug_log to get and provide a debug log.
rohazon
Re: hue sync help
Post by rohazon » 20 Sep 2018, 11:20
koying wrote:
19 Sep 2018, 19:09
Hello Koying,
Thanks for your reply,
i will give two logs, as i encounter another problem, gamepad and remote not acting at startup , i can hear sound as if it working but nothing highlight or open (only "back" command is working), i need to use a mouse and highlights some content on the left side for both remote and gamepad to work.
-hue sync problem log will also contain gamepad log ( log is too heavy for pastebin (1.06 Mo) and don't have pro account, so had to create personal link)
"deleted"
no username
password: huelog
-gamepad log (without huesync activated)
https://pastebin.com/TreVB881
Thanks for your help
Re: hue sync help
Post by koying » 20 Sep 2018, 19:04
Oh, did you enable "Enable capture" in the mrmc codec settings (and accepted the system prompt for capturing frames)?
Might need to make that a bit more obvious ;)
rohazon
Re: hue sync help
Post by rohazon » 20 Sep 2018, 20:41
koying wrote:
20 Sep 2018, 19:04
i did not..., thanks a lot. it is now working :D and Well done to the team for all that job
if i may say so, Transition are brutal compare to huestacean (github project) but still great to have it inside mrmc
Would you also know what is happening with controller/remote not responding?
I already explain before but i will summarize in French as i might explain it better :
après le démarrage de MrMc, alors que j'appuie sur une direction ou sur le bouton A, j'entends bien le bruit associé à un bouton de la télécommande (ou manette), mais à l'écran rien ne se passe . Les 2 seuls boutons à fonctionner sont B et "retour" qui minimise mrmc.
Cependant en activant ma souris et en survolant des médias ou catégories, je peux ensuite reprendre la main avec la télécommande/manette.
let me know if you need more informations
Re: hue sync help
Post by koying » 20 Sep 2018, 22:22
Re hue, there is no transition, indeed. I find it more important for the ambilight to match what's onscreen.
I'm abroad currently, so cannot test gamepad right now.
I'll try to reproduce next week.
rohazon
Re: hue sync help
Post by rohazon » 21 Sep 2018, 06:40
koying wrote:
20 Sep 2018, 22:22
appreciate, thank you
thesuffering
Re: hue sync help
Post by thesuffering » 21 Sep 2018, 16:18
I have this working fine on my Shield TV and Hue setup. Question is, is there a way to not do Ambilight, but rather just have the hue lights dim on play, and go bright again on pause or stop?
