Recommended settings for Shield and MrMC?
Shasarak
Post by Shasarak » 10 Jun 2018, 08:23
There have been one or two other threads about this in the past, but none of them have really produced satisfactory answers, so I'll ask again. :)
When running MrMC on the Nvidia Shield TV, what settings should be used, both on the Shield itself and within MrMC, to get the best possible video and audio quality?
Some notes on my set-up, in case it's relevant:
- The TV is an LG OLED65G6.
- In between the Shield and the TV is a Lumagen RadiancePro video processor.
- Audio at the moment is being handled by my Oppo 105D blu ray player, which has an HDMI input and 7.1 analogue audio out. It can handle DD, DTS and DD+ bitstreamed, but not DTS-HD or TrueHD; it can, however, handle multichannel PCM via HDMI, up to 7.1/24-bit/96kHz, or 5.1/24-bit/192kHZ.
- Videos are read from an NFS share across the LAN.
Other things to note:
- I am extremely sensitive to 60Hz judder on 24Hz source material.
- I always use subtitles when available.
- To get the best out of the Lumagen, it's important that the video output be as "raw" as possible - so ideally there should be no upscaling, deinterlacing, chroma upsampling, or post-processing. This is not feasible for SD sources on the Shield, but I'd like to get as close as possible.
- I watch a mixture of SD, HD, 4K and 4K/HDR material.
tomster
Re: Recommended settings for Shield and MrMC?
Post by tomster » 11 Aug 2018, 12:06
Would like to know exactly the same. What are the best settings for MrMC on a Shield?
21flex
Post by 21flex » 18 Sep 2018, 08:14
sorry to bump up the thread. Is there a recommended settings page yet? Interested in settings for the Shield like we had with SPMC
hifiaudio2
Post by hifiaudio2 » 08 Oct 2018, 01:03
Also interested in this!
tomster
Post by tomster » 08 Oct 2018, 08:50
Going back to Kodi. What a worthless support for this app. Too bad I bought it.
Post by timstephens24 » 08 Oct 2018, 09:27
The settings are going to be dependent on your setup, just like with SPMC or Kodi. If there's something specific you're looking for that would help, but settings I use won't necessarily be settings you use.
Shasarak
Post by Shasarak » 08 Oct 2018, 10:48
timstephens24 wrote:
08 Oct 2018, 09:27
For any one media player device (in this case, the Nvidia Shield TV, running the most recent Nvidia software), how much variation can there realistically be?
EDIT: Koying provided quite detailed recommended settings for SPMC running on the Nvidia Shield TV: https://github.com/koying/SPMC/wiki#Nvi ... d_Specific What's preventing the authors of MrMC from doing the same thing?
Shasarak
Post by Shasarak » 08 Oct 2018, 10:56
tomster wrote:
08 Oct 2018, 08:50
I'm tempted to tag this as the solution to my original question. :roll:
Post by amet » 08 Oct 2018, 13:01
Default settings are the settings we think are the best obviously, otherwise we would not make them default, if that doesn’t work for you for some reason then we need more info on what’s wrong with it to be able to assist.
On my setup, all default settings work once I select 5.1 audio output ... expecting us to guess what’s not okay on your setup is a bit far fetched.
Shasarak
Post by Shasarak » 09 Oct 2018, 09:20
08 Oct 2018, 13:01
Are the default settings different, depending on which Android TV device MrMC is being installed on?
More importantly, what about all the settings on the Shield itself that the MrMC installation has no control over? For example, what colour space(s) do you recommend? What about the Shield's central audio settings, or various other system values?
Also, optimal settings might depend on the TV the Shield is connected to.
Also, when you say things like this:
08 Oct 2018, 13:01
you're implying that "working" and "not working" are the only two possibilities.
I didn't post this because I'm having problems with videos not playing, I posted it because I want to know how to optimise the setup for the best possible sound and image quality.
If we compare SPMC, for example (which I'm more familiar with): if you configure SPMC to decode standard-definition MPEG2 video in hardware, the video plays very nicely; but the image quality you get isn't quite optimal, because it's then using bilinear upscaling. If you set it to decode in software then you can use Lanczos3 scaling instead, which looks better.
It's not the case that using hardware decoding for SD MPEG2 "doesn't work"; but decoding in software is still objectively a better option.
In MrMC everything is "working", but that doesn't necessarily mean everything is optimal.
