BDMV folder playback
cardsdoc
Post by cardsdoc » 08 Jun 2018, 15:39
I'm trying to figure out how to play back BD or UHD BDMV folders. I have added the video source and set content as movie. BDMV folder is within a folder with movie name. If I navigate to movie folder MrMC just opens up the BDMV folders contained within. How do I initiate playback? Thanks.
Re: BDMV folder playback
Post by cosmoxl » 08 Jun 2018, 15:46
cardsdoc wrote:
08 Jun 2018, 15:39
I'm trying to figure out how to play back BD or UHD BDMV folders. I have added the video source and set content as movie. BDMV folder is with a folder with movie name. If I navigate to movie folder MrMC just opens up the BDMV folders contained within. How do I initiate playback? Thanks.
Well, I don't know what remote you're using but you can bring up the menu on the BD folder (with shield remote that's hold down middle button) and you should get an option to play it back. Or click on index.bdmv or movieobject.bdmv within the bdmv folder. You'll get asked what playlist to playback.
cardsdoc
Post by cardsdoc » 08 Jun 2018, 15:55
cosmoxl wrote:
08 Jun 2018, 15:46
cardsdoc wrote:
08 Jun 2018, 15:39
Thanks. I'll give that a try.
cardsdoc
Post by cardsdoc » 09 Jun 2018, 00:46
cosmoxl wrote:
08 Jun 2018, 15:46
cardsdoc wrote:
08 Jun 2018, 15:39
So I tried all those things and nothing happens. I can play on my oppo 203 and on infuse via Apple TV. Not sure what else to try. Also this is via an SMB share of that makes any difference. Thanks.
Post by davilla » 09 Jun 2018, 00:53
cardsdoc wrote:
09 Jun 2018, 00:46
cosmoxl wrote:
08 Jun 2018, 15:46
cardsdoc wrote:
08 Jun 2018, 15:39
Hold the select menu until the pop up comes up. That's a basic operation in MRMC.
cardsdoc
Post by cardsdoc » 09 Jun 2018, 01:06
09 Jun 2018, 00:53
cardsdoc wrote:
09 Jun 2018, 00:46
cosmoxl wrote:
08 Jun 2018, 15:46
Getting to the pop up menu is not my problem. I tried pop up menu->play on bdmv folder and index and movieobject files but no go. Are there any settings from default that should be changed? Do I need a particular folder structure? Right now it’s in a folder named for movie, then AVCD folder within that, then BDMV/Certficate folders within that. This structure with the AVCD folder is required by my Oppo 203 so why I have it like that.
cardsdoc
Post by cardsdoc » 09 Jun 2018, 02:07
Also wanted to add that I’m trying a UHD disc backup not a standard blu-ray. Don’t know if that matters or if UHD is supported.
Post by davilla » 09 Jun 2018, 13:00
works for me :)
Skunkworks:mrmc-private davilla$ ls -l /Volumes/Multimedia/Work/hevc/Blade.Runner.1982.BD25.UNTOUCHED.VIDEO.TrueHD
total 72
drwx------ 1 davilla staff 16384 Feb 6 20:08 BDMV
-rwx------ 1 davilla staff 1313 Oct 30 2017 Blade.Runner.1982.BD25.UNTOUCHED.VIDEO.TrueHD.nfo
drwx------ 1 davilla staff 16384 Oct 18 2012 CERTIFICATE
Skunkworks:mrmc-private davilla$ ls -l /Volumes/Multimedia/Work/hevc/Blade.Runner.1982.BD25.UNTOUCHED.VIDEO.TrueHD/BDMV/
total 272
drwx------ 1 davilla staff 16384 Oct 18 2012 AUXDATA
drwx------ 1 davilla staff 16384 Oct 18 2012 BACKUP
drwx------ 1 davilla staff 16384 Oct 18 2012 BDJO
drwx------ 1 davilla staff 16384 Oct 18 2012 CLIPINF
drwx------ 1 davilla staff 16384 Oct 18 2012 JAR
drwx------ 1 davilla staff 16384 Oct 18 2012 META
-rwx------ 1 davilla staff 290 Oct 18 2012 MovieObject.bdmv
drwx------ 1 davilla staff 16384 Oct 18 2012 PLAYLIST
drwx------ 1 davilla staff 16384 Oct 18 2012 STREAM
-rwx------ 1 davilla staff 120 Oct 18 2012 index.bdmv
Post by cosmoxl » 09 Jun 2018, 13:16
cardsdoc wrote:
09 Jun 2018, 01:06
09 Jun 2018, 00:53
cardsdoc wrote:
09 Jun 2018, 00:46
I'd click play on the AVCHD folder but it could be that MrMC isn't supporting AVCHD structure but only blu-ray. I've had to do the same thing with my Oppo in the past - use tsmuxer to convert blu-ray to AVCHD.
cardsdoc
Post by cardsdoc » 09 Jun 2018, 13:21
09 Jun 2018, 13:00
works for me :)
total 72
total 272
Thanks again. I wonder what I’m missing. Must be something simple but just don’t know.
Users browsing this forum: koying and 2 guests
