MrMC lite
sfanetti
MrMC lite
Post by sfanetti » 30 Apr 2018, 12:26
Good morning, I bought an Nvidia Shield Tv and I would to test MrMC for stream my local video file (on NASA qnap) to the shield. I tried to download the MrMC Lite version but it tell me that it's incompatible, however the full version is ok. I want to try the free version for verify if it's a good product and if it's ok for me and then, I will purchase the product. Can you give me the APK of the free version to test? Thank you very much. Good work
Re: MrMC lite
Post by koying » 30 Apr 2018, 15:09
Fixed now.
Thanks for the report.
gatorchamp85
Re: MrMC lite
Post by gatorchamp85 » 02 May 2018, 20:20
Just wanted to pass along that this is still showing as incompatible with the Shield in the Play store.
LePousson
MrMC lite
Post by LePousson » 03 May 2018, 01:50
I could get the Lite version, but when starting it, i got this :
ImageWhat did I do wrong ?
LePousson
LePousson
Re: MrMC lite
Post by LePousson » 07 May 2018, 13:00
Do someone has an idea please ?
LePousson
Re: MrMC lite
Post by koying » 07 May 2018, 13:03
Did you try to deinstall and reinstall?
LePousson
Re: MrMC lite
Post by LePousson » 07 May 2018, 13:08
Yes but still getting the same error ... What can I try now (except resetting totally my Shield) ??
LePousson
LePousson
Re: MrMC lite
Post by LePousson » 07 May 2018, 13:57
I finally could get the Lite version installed and running ...
But I had to uninstall SPMC and Kodi, and then look for every related file and remove all of them manually ...
I will now test this Lite version but I noticed that when Passthrough is enabled, IEC or not, does not give any sound .. anything to check ?
LePousson
