Google Play Store Versions
barong
Post by barong » 26 Apr 2018, 14:44
I notice that MrMC is now available to purchase via the google play store on my 2017 Sony Android TV.
I noticed there is also a “lite” version, but this does not appear.
The full version says it is compatible with the device, but the lite version says it is not compatible?
Is there a technical reason for this?
Thanks in advance.
Re: Google Play Store Versions
Post by koying » 26 Apr 2018, 15:55
It's fixed now. Thanks for the report.
barong
Post by barong » 26 Apr 2018, 20:50
Thanks for the prompt fix :D
McKentin
Post by McKentin » 28 Apr 2018, 19:53
Is it by any chance region locked? I have a Sony 4k android tv and i don't see it in the playstore.
SUPERBIF
Post by SUPERBIF » 01 May 2018, 13:58
Will it be possible to support MiBox also?
SUPERBIF
Post by SUPERBIF » 04 Jun 2018, 11:26
Will I be able to install it on MiBox also?
Post by koying » 04 Jun 2018, 16:39
You should, if it's not unlocked/rooted
SUPERBIF
Post by SUPERBIF » 05 Jun 2018, 06:17
Ok thanks and it's not rooted or anything
SUPERBIF
Post by SUPERBIF » 08 Jun 2018, 18:06
Hi again i cant find it in play store on mibox. Can i buy it and get apk and sideload it or why can't i find it in play store?
barong
Post by barong » 08 Jun 2018, 22:12
Think MiBox is running an older/unsupported version of Android TV
