Make "Videos" go to file mode
Any Amber skin issues go here
Moderator: pecinko
Maetrik
Post by Maetrik » 28 Dec 2018, 23:26
Hi there,
is it possible to add an option that "Videos" goes to file mode directly? You can do this for TV Shows and Movies already, but not for Videos. The same option for Music would be great aswell :)
Also, when using the vertical menu and blending out some menus, the focus goes crazy. I just use Videos, Movies, TV-Shows and Settings and when starting MrMC the focus is on settings which is totally useless.
Regards,
M.
