Plex Addon Subtitle issue with multiple versions of same movie
Any issues that are Plex Addon related
generic
Post by generic » 25 Nov 2018, 03:13
Hello,
I'm running MrMC 3.7 on an Apple TV TVOS 12.1, and I noticed when I have two copies of the same movie, (1080p and 4k, for example), I can click the button with the 3 periods, and select which version I want to play, but when I try to select the PGS subtitle tracks integrated into the MKV files, it doesn't work properly. Instead of seeing just the subtitle tracks, in the selection list, for the version of the file I'm playing, I see the subtitle tracks for both the 1080p file and the 4k file, and selecting one from the list doesn't always work. I also can't turn off subtitles, unless I select the MrMC audio menu, while playing the file, and de-select the "enable subtitles" option there.
If I only have a 1080p or a 4k version of a file, it works as expected.
Has anyone else run into this problem?
Thanks for your time.
