Can’t save settings in pause jumpback extension
Any issues that relate to Addons
wgstarks
Post by wgstarks » 10 Jan 2019, 13:34
When I try to configure the extension using Apple remote or Kodi iOS remote I can select the various settings and adjust them but can’t actually enter the setting and navigate to the OK button to save settings. The only way I could find to exit the configure pane was using the Menu button and all settings were lost.
________
Walter
