TVMosaic update
Any issues that relate to Addons
TVMosaic update
Post by cosmoxl » 01 Dec 2018, 15:18
https://forum.tv-mosaic.com/viewtopic.p ... t=10#p3977
I think it's implied in this post that there's an update to the TVMosaic add-on that can be brought into MrMC.
Thanks!
Re: TVMosaic update
Post by amet » 01 Dec 2018, 16:18
it specifies kodi 18, in which I am not sure what has changed in PVR addon handling.
@dvblogic is there anything we should worry about?
Montoya
Re: TVMosaic update
Post by Montoya » 01 Dec 2018, 19:24
01 Dec 2018, 16:18
Resume points of recordings are interconnected now when using Kodi new TVMosaic PVR and TVMosaic Client apps.
Watching a recording now on a TVMosaic client app, makes resuming at the same point possible with new PVR version.
Vice versa the same, watching a recording with new PVR version, makes resuming at same point possible on TVMosaic Client apps.
Current MrMC TVMosaic PVR only uses his own resume points, without taking notice of resume points of TVMosaic Client apps for a recording.
Apple TV 4K 64GB tvOS 12.1.2, Win10 Pro x64 1809 build17763.292
TVMosaic server build 17051, Emby server build 4.1.0.1 beta
Re: TVMosaic update
Post by amet » 03 Dec 2018, 13:27
https://github.com/MrMC/pvr.tvmosaic/co ... 4118ef4214
thanks to @dvblogic for pointing out what was changed... we hope to get it in the next TF
