Keymap editor plugin broken
Any issues that relate to Addons
Jxplex
Post by Jxplex » 30 Sep 2018, 19:45
This is my experience from both my shield & my fire TV 4k
The keymap editor, when you go to record button presses, seems to not record the press correctly, where it usually shows a number for which key you pressed it's just blank. Then when you save it, nothing has really changed. When you go to open the addon again it says the keymap file is corrupted or something along those lines. Manually copying in my key combo file from spmc is a temporary workaround.
Perlbo
Re: Keymap editor plugin broken
Post by Perlbo » 12 Oct 2018, 23:21
Hi. In My shield key is recognized but it does not work. Under global addon I want to start advanced wol launcher with key. After saving the key I try to test, but nothing happens.
