Manual Emby Login with https
RalphK
Post by RalphK » 13 Dec 2018, 04:14
I have successfully logged into my Emby server via https. I used the manual method. And I believe that I logged in successfully because on the Emby setup screen, I now see the option to “logout”.
However, when I return to the home screen, there is no media available. I stopped and restarted MrMC but the issue persists.
I have probably missed a step but I cannot figure out what to do next. I am using MrMC on an iPhone 8 with IOS 12.1.
Emby’s own IOS client is working fine on the same phone, so it does not seem to be a connectivity issue.
Thanks for your help,
Ralph
Re: Manual Emby Login with https
Post by amet » 13 Dec 2018, 13:12
Did you select Emby server?
What skin are you using?
RalphK
Post by RalphK » 13 Dec 2018, 15:19
In MrMC, I have manually signed into my Emby server, on the screen
/Settings/Services/Emby Client
Other than that, I am not sure where to "select Emby server."
What have I missed?
I am using the default skin, named Opacity.
Ralph
Post by amet » 13 Dec 2018, 15:40
In opacity, bottom left button has a list of servers... pick it in there
RalphK
Post by RalphK » 13 Dec 2018, 15:51
Thank you. That solved the problem.
I knew that I had missed something!
Post by amet » 13 Dec 2018, 16:06
It’s not you, it’s a bug in 3.7.0 unfortunately... it has been corrected in 3.7.1
gnollo
Post by gnollo » 02 Jan 2019, 12:02
13 Dec 2018, 15:40
Where is this button? I am also logged in remotely via my phone but cannot see any button but a back arrow.
I am in Settings / Services / Emby client.
Like for Ralph K, I use opacity and the screen reports sign-out as option but no movies are showing at all when I go back to the initial screen, which shows "Media sources" and "Quit".
I installed MrMC on a Samsung Android phone.
Post by amet » 02 Jan 2019, 12:44
gnollo
Post by gnollo » 02 Jan 2019, 13:38
Only MrMC showing in the list. Selected, makes no difference.
Post by amet » 02 Jan 2019, 13:41
that means that your Emby has not logged in properly or it has not found any library sections. debuglog might have some answers
