How does MrMC's Emby client stream content?
Theogeek
Post by Theogeek » 01 Oct 2018, 02:19
In Kodi, I can choose how Emby content is streamed (either direct play or htsp). I care, primarily for the subtitle downloading (so the subtitles are stored in the same folder as the content). In Mr.MC, I can't download subtitles for any content because the title it uses to search for is "stream" no matter what content I am using. And, if I try to enter a manual string in the search box, it doesn't use what I typed and defaults to "stream".
Am I doing something wrong, or is subtitle downloading broken?
Thanks!
Theogeek
Re: How does MrMC's Emby client stream content?
Post by Theogeek » 03 Oct 2018, 02:10
huh...for whatever reason, it started working - it no longer reports the name as "stream". It now however does download the subtitles, but saves them in the TEMP folder and does not keep them around. No matter what I select as the option "store next to movie" or "store in custom folder", it does not store them where I specify and always stores them in a temp folder.
Post by amet » 03 Oct 2018, 04:37
Yeah, that’s how it was intended
Both plex and emby have subtitle download option, downloading them on MrMC is the last resort if emby didn’t find anything.
On my to-do list is to look into saving subtitles locally in a better way so that they can be reused
