MrMC does not alway show movies after wol
sylvio2000
Post by sylvio2000 » 18 Jun 2017, 06:54
Hi.
I have MrMC with amber in use. I only use nextpvr and emby client.
If I start MrMC wol works and "tv" comes up, but not "movies" and "tvshows". I then have to first close MrMC and start it again. Then everything is there.
log:
https://pastebin.com/x1cAfGhG
Re: MrMC does not alway show movies after wol
Post by amet » 18 Jun 2017, 07:50
are Emby and nextpvr both on 192.168.178.15? is content for emby on the same machine?
its possible that emby just takes a bit longer to wake up ...
EDIT: try 3.0.6, we have added some more changes that could help with WOL
sylvio2000
Post by sylvio2000 » 18 Jun 2017, 13:11
NextPVR, Emby server and content is on 192.168.178.15.
I will try it.
sylvio2000
Post by sylvio2000 » 19 Jun 2017, 13:59
Do you mean 3.0.7 ?
3.0.6 is already in use
Post by amet » 19 Jun 2017, 16:24
your log shows 3.0.5
08:48:09 T:367935646272  NOTICE: Starting MrMC (3.0-5 Git:2017-05-31-d53328e). Platform: Android ARM64 64-bit
sylvio2000
Post by sylvio2000 » 20 Jun 2017, 17:47
You are right. I used 3.0.5. I dont know why it did not update.
Now I tried with 3.0.6 but there is the same problem:
https://pastebin.com/r1iMsqsL
Post by amet » 20 Jun 2017, 20:20
Make sure MrMC can see emby, disable and re-enable WOL service and try again.
Try to capture the debuglog when you do that and if it fails again please
sylvio2000
Post by sylvio2000 » 21 Jun 2017, 06:20
OK, I can do that, but the problem is not that the server not wakes up. MrMC always sends a wol signal and the server wakes up.
The problem is only that I cant see "movies" and "tvshows". I have to start MrMC again and then everything is there.
Post by davilla » 21 Jun 2017, 11:41
sylvio2000 wrote:
21 Jun 2017, 06:20
Do an update lib and see if "movies" and "tvshows" return. And debuglog after you do this.
sylvio2000
Post by sylvio2000 » 23 Jun 2017, 13:35
Ok I started MrMC and updated the library. Nothing changed:
https://pastebin.com/mv4vrxWC
