No wol and no collections
sylvio2000
Post by sylvio2000 » 06 May 2017, 08:00
Today I tried MrMC 3.0.3 from fresh on my AFTV2.
I only configured my emby server (local) and the NextPVR client (both on the same server).
Problems.
1. There is no possibility to wol my server. I use amber skin and I can only see the menu "Exit". There is no "tv", "tvshows" or "movies" from where I could access my server to wol it.
2. If I start my server manually everything is fine except the collections. I can see them in the library but I cannot open them. If I click on it nothing happens
sylvio2000
Re: No wol and no collections
Post by sylvio2000 » 08 May 2017, 06:28
Am I the only one with this problem?
I have already enabled "try to wakeup remote servers on access". But this doesnt work if I only have configured emby and nextpvr.
Maybe the most simple solution would be an option to wol my server as soon as MrMC ist started.
Post by amet » 08 May 2017, 10:41
will look into it, our servers don't sleep so we have no issues like that :)
sylvio2000
Post by sylvio2000 » 09 May 2017, 06:23
Thanks.
I found another issue. Yesterday my internet connection was broken and it was not possible to access my emby library within MrMC. I choose manual sign in and I only have a local server in the same subnet.
Post by amet » 09 May 2017, 06:59
sylvio2000 wrote:
09 May 2017, 06:23
Thanks.
pin signin relies on internet, thats how it works unfortunately ... however, if you do a manual sign in using local LAN server IP you should be able to log into it
sylvio2000
Post by sylvio2000 » 12 May 2017, 07:34
Today I tested again:
1. First I put off the internet cable out of my router. Then I started my server. After that I started MrMC. Tvshows and movies dont appear.
Then I put in the internet cable again and tvshows and movies appeared again.
2. On my emby server I use the plugin "Auto Box Set" which automatically creates collections. Maybe your emby implementation is not compatible with this plugin?
Post by amet » 12 May 2017, 07:48
sylvio2000 wrote:
12 May 2017, 07:34
how did you sign in? manual or by Pin?
sylvio2000 wrote:
12 May 2017, 07:34
I will add it to our "to-do"
sylvio2000
Post by sylvio2000 » 12 May 2017, 09:11
I sign in manual
Post by davilla » 12 May 2017, 11:08
internet cable attached, manual sign-in, let emby services appear. Now pull internet off router. Can you still access local emby ?
in MrMC.log, do you see
CEmbyServices::Process has gateway1
followed by
CEmbyServices::Process has gateway2
sylvio2000
Post by sylvio2000 » 12 May 2017, 17:20
Yes it works if I do it like you said.
Sadly I have no log. I will try again later with log.
