problem with ac3 tracks since last update
Rootax
Post by Rootax » 31 Dec 2018, 09:13
Since the latest beta (supposed to fix some ac3 problems), videos with Dolby digital / ac3 tracks are problematic. Every 2 secondes the sounds goes off, then on again, then off, etc. It's not like the volume goes to 0, no, it's that no audio signal is sent to the amp.
E-AC3 and all other formats are ok, only AC3 tracks are problematic now.
Thx.
https://pastebin.com/VDjJmGHN
Rootax
Re: problem with ac3 tracks since last update
Post by Rootax » 15 Jan 2019, 22:13
No one ? :/
jumbo_
Post by jumbo_ » 16 Jan 2019, 22:37
Same here, My setup is FireTV2 -> Denon1920.
If passthrough is enabled, the sound on AC3 goes on and off in regular short intervals. Also gets out of sync quickly. DTS works fine.
If passthrough is disabled, there are no issues.
I can create a debuglog as well, if needed.
Angryunibrow
Post by Angryunibrow » 19 Jan 2019, 19:15
I have this issue also, had to turn off AC3 in passthrough settings.
