Unwatchable Live TV
tredman
Unwatchable Live TV
Post by tredman » 28 Jun 2018, 11:10
Ok, my post on the testflight section got completely ignored, so I thought I would repost here:
Been meaning to report this for ages, but not had time. For a good while I have had issues with live tv on the test flights, stuttering and dropped images and sound - its completely unwatchable. I'm watching UK DVB-S2 HD content from tvheadend - works fine in SPMC & Android Kodi.
Log is here:
https://pastebin.com/qivT7xc2
I have exactly the same issue on all my shields (mix of 4k, 1080p and 720p outputs).
If you I can help with more info please let me know.
Edit - note although this log is from one of my sheild running on Oreo I see *exactly* the same issue on the 2 shields which are not upgraded to 8
If anyone has live tv working correctly, please could they post their settings?
Re: Unwatchable Live TV
Post by amet » 28 Jun 2018, 11:55
I watch tvheadend and iptv setup on mix of Shields and ATV4/4K without any issues.
is it every channel? how is your streaming setup on TVH? mine is all default on MrMC and TVH.
tredman
Post by tredman » 28 Jun 2018, 14:10
All settings are default on tvh and mrmc.
I'm watching mainly 1080i h.264 content from dvb-t2 and dvb-s2 (hdhomerun and digibit R1).
I've even tried a different tvh server and it's the same.
tredman
Post by tredman » 05 Jul 2018, 16:49
So it looks like I'm the only one with this issue on the shield with 3.70?
Guess I will have to go back to Kodi :(
Post by amet » 05 Jul 2018, 20:43
15:36:26.181 T:153568986352   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - profile name: webtv-h264-aac-matroska, comment: WEBTV profile H264/AAC/Matroska added
15:36:26.181 T:153568986352   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - profile name: webtv-h264-aac-mpegts, comment: WEBTV profile H264/AAC/MPEG-TS added
15:36:26.181 T:153568986352   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - profile name: webtv-vp8-vorbis-webm, comment: WEBTV profile VP8/Vorbis/WEBM added
15:36:26.181 T:153568986352   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - profile name: htsp, comment: HTSP Default Stream Settings added
my money is on a setting issue... do you have PVR addon setup to use profiles? hows the user setup under TVH? you can assign the streaming profile there as well. my user does not have any profiles assigned and PVR addons is set as default(no profile selected)
tredman
Post by tredman » 06 Jul 2018, 15:33
I've literally done nothing to settings, other than enter the ip address of the server. I will see if I can force it to use htsp.
Edit - this particular tvh server is brand new, running on LE with everything standard.
tredman
Post by tredman » 06 Jul 2018, 15:45
New log here, first checked stream field is empty (it was) - still same problem.
Then entered htsp in stream field, still same problem
https://paste.ee/p/VJta7
Post by amet » 06 Jul 2018, 20:59
is there any specific reason why you are on a Beta build from a week ago? there has been some fixes and builds in between.
try updating to latest 3.7.0 and lets see if thats any better. if you go to 3.6.2 does that fix the issue?
EDIT: I could be wrong about what last beta is, but try 3.6.2 and see if that fixes it for you.
tredman
Post by tredman » 07 Jul 2018, 06:03
Going to 3.6 builds does fix the problem, but isn't a donwgrade simply deferring the problem?
Post by koying » 07 Jul 2018, 07:16
Any chance to get a sample or get access to your TVH?
