Library automatic clean-up
gpmc01
Post by gpmc01 » 17 Feb 2017, 00:38
Hello!
I'm used to attach to the Shield TV various USB drives based on the content I want to see (movies, TV shows, documentaries, etc.) and I would be interested in a feature that is going to enable/disable the automatic clean-up of the library when new USB device (with, obviously, a different content from the one currently "stored" in the Shield) is connected showing only the content of the current device and therefore prenventing to select something that is not physically present.
Do you think that this could be implemented in upcoming MrMC builds?
Thanks in advance.
Re: Library automatic clean-up
Post by davilla » 17 Feb 2017, 00:58
If I get you right, you want a 'clean lib' function that only cleans lib sources that are attached and ignores unattached sources.
gpmc01
Post by gpmc01 » 17 Feb 2017, 01:07
Exactly.
Content of unattached sources should not be displayed if this feature (auto-cleanup) is enable from the "settings" panel.
Post by davilla » 17 Feb 2017, 01:54
gpmc01 wrote:Exactly.
That would be another 'feature' request :) We will discuss it internally. There would have to be some way to purge all or the lib can grow without bounds and that might cause problems.
gpmc01
Post by gpmc01 » 17 Feb 2017, 02:07
gpmc01 wrote: .... There would have to be some way to purge all or the lib can grow without bounds and that might cause problems.
This is really a good point as well.
gpmc01
Post by gpmc01 » 18 Feb 2017, 15:00
Any chance to have this feature considered by Dev Team for future release of MrMC?
Post by davilla » 18 Feb 2017, 15:01
gpmc01 wrote:Any chance to have this feature considered by Dev Team for future release of MrMC?
heh, I did say we are discussing it :)
gpmc01
Post by gpmc01 » 18 Feb 2017, 15:07
OK!!!!! Thanks a lot.
In the meantime I really enjoy your app that works perfectly (at least for me) on latest Shield Experience 5.1.
gpmc01
Post by gpmc01 » 07 Jul 2017, 03:28
Dear Dev Team,
any update on this?
Is there any chance to get this feature in upcoming releases of MrMC?
Thanks in advance!!!
