ERROR: AESinkAUDIOTRACK::GetDelay over-write error
theRCRH
Post by theRCRH » 30 Aug 2018, 00:36
I'm having a problem with audio going out of sync during playback.
I have passthrough enabled and AC3 transcoding turned on as my soundbar doesn't support DTS.
The error in my log is
ERROR: AESinkAUDIOTRACK::GetDelay over-write error, frameSize=4, headBytes=36057101, m_writeBytes=
with the m_writeBytes= number changing.
This same error gets written about 100 times per second into the log file until I stop playback.
When I restart playback the audio is back in sync.
I can also correct the sync error if I bring up the audio settings and toggle off passthrough (but then I loose surround sound).
The error seems to start if I use the arrow keys to jump ahead in the video but sometimes it happens without any adjustment to the playback position.
Re: ERROR: AESinkAUDIOTRACK::GetDelay over-write error
Post by davilla » 30 Aug 2018, 11:59
theRCRH wrote:
30 Aug 2018, 00:36
Too little info to describe the issue. Debuglog please and describe your equipment setup.
theRCRH
Post by theRCRH » 30 Aug 2018, 14:13
I'll turn debug logging on tonight.
theRCRH
Post by theRCRH » 02 Sep 2018, 02:13
here's my error log (I had to delete the thousands of repeating error lines to get it to fit in pastebin).
https://pastebin.com/s3mfHeJd
Here are the specs on my android box.
Arcadyan Technology HMB2213PW Digital TV Box
https://sites.google.com/view/droid-tv/ ... lus-pik-tv
I have two of these and both are giving the same error.
One is connected to a Vizio soundbar and then to a samsung TV. The other is connected to a Vizio TV and then to a Sonos soundbar.
I hope this helps.
Post by davilla » 02 Sep 2018, 02:28
2018.1080p.bdrip.10b.hevc.dts
So 1080p, hevc, 10bit with dts. on a dual core ARMv7. While the box seems to be able to handle 8bit hevc, I see nothing about 10b.
I suggest testing with standard h264, h265 media content.
theRCRH
Post by theRCRH » 02 Sep 2018, 15:27
I'll get a log file but I've had the same error with a 720p x264 file with DD5.1
theRCRH
Post by theRCRH » 03 Sep 2018, 05:07
here's another log with the same error.
720p x264 with dd5.1 audio being passed through. A couple of seconds in and the audio goes out of sync.
https://pastebin.com/6hEb4r8E
Post by davilla » 05 Sep 2018, 00:57
how is your mrmc audio setup ? IEC frame packing ?
theRCRH
Post by theRCRH » 05 Sep 2018, 16:01
Yes, IEC packed is on but I've had the error with it off too.
channels: 2.0
out config: optimized
stereo upmix: greyed
boost center: 0
resample: medium
keep device alive: 1 minute
- level of silence: default
play gui: only when stopped
enable passthrough: true
format is iec packed: true
AC3: true
-ac3 transcode: true
e-ace: true
DTS: false
true-hd: false
DTS-HD: false
theRCRH
Post by theRCRH » 10 Sep 2018, 15:43
Did I come up with a stumper?
