Hello,
Looking to switch to MrMc, i've tried to install MrMc from playstore.
Strange any of my devices are compatible samsung S3, S5, KII amlogic, himedia H8, and the most important for my use the Sony X85 4K.
I've found MrMC lite (with odd files) on apkdownload. By the way, the only apk version have an error message about download odd to sdcard.
So I Install it, click on the leanback icon, It's working fine on my TV !!!!
The lite version can show only 8 files and I can't purchase the "full" version from the playstore, because unrecognize devices.
Any Idea ?
unable to install MrMC form playstore
Re: unable to install MrMC form playstore
Is this post specific to the Nvidia Shield TV? Because it should be.
You can browse to the playstore link on a computer (https://play.google.com/store/apps/deta ... .mrmc.mrmc) and remotely install it to the Nvidia Shield TV from there. This works as long as you are logged into your Google account on the device which you are trying to install MrMC.
