Mounted SMB in Library
rodalpho
Post by rodalpho » 08 Oct 2017, 16:19
I have my NAS mounted on the ShieldTV and MrMC sees it as "Media". Is there any way to add a path like "Media/Movies" to my library, so I can use the mounted path rather than MrMC's built-in SMB support? MrMC is unable to browse to the root filesystem, I assume due to android sandboxing.
Re: Mounted SMB in Library
Post by timstephens24 » 08 Oct 2017, 16:22
It's better to use MrMC's built in SMB, but you should be able to navigate to your Shield's mounted folders in the Videos section. I have my NAS attached to my SHIELD for the Plex Server, and I can see my SHIELD mounts in MrMC.
rodalpho
Post by rodalpho » 08 Oct 2017, 16:46
I can navigate to it just fine, but I want to add it to my library.
Edit: I figured it out, go to the file view then hit the context button and "set content type" and it gets scanned to the library flawlessly. Never did it this way before, always had to add a source.
Post by timstephens24 » 08 Oct 2017, 17:06
Long press and hold on the folder you want to add, then choose 'Change Content' (or maybe 'Edit Source'... I haven't done it in awhile and doing this from memory). That'll let you set it as Movies/TV Show/etc and get added to your library.
rodalpho
Post by rodalpho » 08 Oct 2017, 17:06
I edited my post and you posted simultaneously. Thank you!
