Trouble Building in Xcode
Development talk only
ams123
Post by ams123 » 22 Mar 2018, 18:25
I am missing PRODUCT_BUNDLE_IDENTIFIER
But I think that is the result of the missing info.plist even thought I have use the selcted the info.plist file under the target/identity.
I am also missing Commmon.xcconfig
During he configuration both
$ make clean
$ make xcode_depends
failed with "make: *** No rule to make target"
Re: Trouble Building in Xcode
Post by davilla » 22 Mar 2018, 18:48
make -C tools/depends/xbmc
ams123
Post by ams123 » 22 Mar 2018, 19:03
22 Mar 2018, 18:48
No such file or directory.
make -C tools/depends/target/xbmc
runs with error:
configure: error: Could not find a required library. Please see the README for your platform.
make: *** [../../../..//libMrMC.so] Error 1
Post by davilla » 22 Mar 2018, 19:34
you did not buiid depends. Which means you did not read the readme's.
tools/depends/README
docs/README.ios
docs/README.android
MrMC is a very difficult application to build. As are it's forks (Kodi/SPMC).
ams123
Post by ams123 » 22 Mar 2018, 20:37
22 Mar 2018, 19:34
docs/README.ios
docs/README.android
Read the ios readme but never not the depends, not sure where that was referenced. Only difference was to rerun as 64 bit since 32 bit is not longer supported. Regardless same results.
Seems to require Java, which I installed, is there some specific setup required there?
Post by davilla » 22 Mar 2018, 21:27
depends build
./bootstrap
./configure --host=arm-apple-darwin --with-tarballs=/Users/Shared/tarballs --prefix=/Users/Shared/mrmc-depends --with-cpu=arm64
./configure --host=arm-apple-darwin --with-tarballs=/Users/Shared/tarballs --prefix=/Users/Shared/mrmc-depends --with-cpu=arm64 --with-platform=tvos
java is required.
if depends build fails, have to figure why, then make distclean and try again. We build under 10.13 and Xcode9 (9C40b). Xcode 8 is not supported, nor any beta Xcode versions.
