Hello
Introduce yourself here
logan_x50
Hello
Post by logan_x50 » 07 May 2016, 07:22
I started using XBMC with my AppleTV1 and well remember Davila's great posts (often snippy) and superb work e.g CrystalHD and Android port. I was searching for the updated firestarter as I missed being able to update through it. I stumbled across MrMC on AFTVNews which i had heard about on the Kodi forum but hadn't realised the great and powerful Davilla was heading it. I had last come across Davilla in connection with XBMC on the Gamestick (but the less said about that the better). Anyway, purchased MrMC immediately out of solidarity in some strange way (if you've followed the recent comings and goings over in Kodi Android land you'll know what I mean).
A couple of questions/requests:-
1) Is the log off screensaver available? I use it as i have a kids profile as well as master profile
2) will the Estuary skin become available or does it also use Python? Confluence is very tired and i was looking forward to the new skin when i jumped to Kodi 17
Good luck with MrMC (not sure about the name guys) @Davilla and @Amet
Re: Hello
Post by davilla » 07 May 2016, 13:26
thx, :) The all and powerful oz here.
We got tried of the endless bikeshed'ing and branched out on our own.
Which addon is the 'log off screensaver' ?
Estuary skin is nice, we are watching it develop. Needs core changes to support the changed skin API under v17.
logan_x50
Re: Hello
Post by logan_x50 » 08 May 2016, 16:54
I checked and the add-on is from Elmerohueso. available in the official kodi repository
Re: Hello
Post by amet » 08 May 2016, 17:02
I looked at that and it seems doable, only problem is that we use apple screensaver. that means that application goes in the background while screensaver is on.
one option would be to logout every time app goes in the background, screensaver or 'menu' button to back out into Apple home screen... that would be easy and can be done without too much impact on other aspects of application
