Device Compatibility
Introduce yourself here
RKCRLR
Post by RKCRLR » 19 May 2018, 16:54
Is there a list of compatible devices/OS's somewhere? I've searched your website and Wiki but couldn't find one. I was going to try MrMC Lite on my AZW W95 streaming box (S905W processor running Android 7.1.2 - not Android TV) but Google Play store and Amazon say it is not compatible. However they say MrMC is compatible with with my Samsung Galaxy S7 phone running Android 7.0.
RKCRLR
Re: Device Compatibility
Post by RKCRLR » 22 May 2018, 01:29
Should I ask this question in a different forum? I'm starting to suspect that MrMC isn't for standard Android devices.
Post by davilla » 22 May 2018, 13:35
RKCRLR wrote:
22 May 2018, 01:29
It is. amlogic boxes can be troublesome, aml continues to do hacks.
Post by koying » 22 May 2018, 14:30
Unsurprisingly, I find no "AZW" devices in the Google device list...
I read that Google is to be more strict regarding uncertified devices using the playstore. Maybe that's the issue?
See https://www.androidpolice.com/2018/03/2 ... eres-deal/
RKCRLR
Post by RKCRLR » 24 May 2018, 01:26
AZW is the parent/sister company of Beelink (which isn't on the list either). I don't think it is the issue of Google blocking my device since I don't get the message and I'm not aware of any other apps that should be compatible but aren't (I've installed SPMC from the Playstore).
Is it possible it isn't compatible because my device is rooted?
Is there a way to sideload MrMC? If so, what version and from where?
What MrMC subforum should I monitor?
Post by davilla » 24 May 2018, 12:51
RKCRLR wrote:
24 May 2018, 01:26
Sorry but MrMC is only available via the App stores (Apple, Amazon, Google Play).
Post by amet » 24 May 2018, 13:32
Someone reported being unable to install on Shield with unlocked bootloader... is that what rooted means in android world?
wesk05
Post by wesk05 » 24 May 2018, 15:27
Does it have anything to do with aarch64? I thought I had read somewhere that MrMC ran only on 64bit builds.
Post by davilla » 24 May 2018, 16:06
wesk05 wrote:
24 May 2018, 15:27
that's changed since koying took over android side
wesk05
Post by wesk05 » 24 May 2018, 18:08
24 May 2018, 16:06
I see. It looks like the requirement for Android 7 and up hasn't changed. All my Amlogic and Realtek boxes show up as incompatible. I think they are all on Android 6. I will have to check one of the Amlogic boxes with Android 7 firmware.
